20 Most Recent
PNY 4GB Micro Attache USB 2.0 Flash Drive Questions & Answers
I have 4 gb pen
it might not seem to be detected but try going to the control panel > admin tools and open computer management then where you see storage open the sub menu there and click disk management and see if it shows there if not let me know could be a case of a dead USB drive or that its having a problem being detected at all....l
Computer keeps telling me to format usb stick if i do i lose all my data
click start control panel administration tools computer management disc management right click on your drive select properties tools check now scan for and attempt to recovery bad sectors and
automatically fix any file system errors tick in both boxes or tick one box then wait until it has finished then return and tick in the other box
i have found the best results ticking the first box then returning after chkdsk has finished automatically fixing files
you should have no input while chkdsk is running any input might further damage your hard drive
hope this helps you
PNY Attache flash drive not being recognized
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Cannot delete pictures from my
Check to see if you have the lock switch on, this is a small slider on the side of the card. If it's enabled you will need to slide it to unlock and place it back into the computer/camera. You will then be able to delete the contents of the card.
Windows XP home edition not
control panel admistrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not workingports(com&lpt)right click update driver
Disk says write protected, won't
click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have full control in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XPalsoIf you are running a Windows XP OS then you might be able to: click start right click on my computer select openRight click the icon of your Flash Drive (It should be F: / E: or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control.
hope this helps you
Dont know how to delete
You can do it to ways
Open up My computer
open removable storage drive may be called PNY or something like that.
right click and delete a file
or you can hit the delete key on the keyboard
Note:
If the need to delete multiple files simply hold the left mouse button and drag a selection box around what you want to delete. Then do one of the above Delete commands.
How do I use this product to save photos off my
Moving files from your computer to the USB flash drive is simple. Plug in your flash drive. Go to "Computer" or "My Computer". You should now see your flash drive show up under a drive letter, like E: or F: for example. Double click this drive letter and a window should open up. Alternatively, when you plug in the flash drive you may get a message on your computer with an option "Open/View folders and files". You can click this to open the flash drive window.
Now, go to the location on your computer where the photos are located. You can use your mouse, click and hold , drag the mouse over files you wish to move. Now that the photos are highlighted, you can click, hold and drag them to the flash drive window. Alternatively, you can right click on pictures and choose the "copy" option. You can then right click inside of your flash drive window and chose "paste". Either of these options will move the photos from your computer to your flash drive.
Regards,
G33k
This is my first flash
Flash drives are used like floppy discs. Take off the cover, plug in the drive to a USB port and wait for the computer to acknowledge it. Usually it will get a drive letter assignment of E: unless you have multiple optical drives or a card reader that may have that drive letter in use. Transfer files by copying them in the file explorer. I like to have two windows open (one with the folder the file is starting in and the other the window for the contents of the flash drive).
Alternatively, open the file in the appropriate program and (for most OS versions) File > Save As and browse to the flash drive. Check the file name and click OK.
To use a file on any computer, open the file explorer and browse to the flash drive. Double click on the file and the associated program (or another that handles that file type) will open if it is on that computer. Then you can edit the file. If you are using a different computer, when you return to your main computer. Transfer the file back to the Documents (My Documents) or other folder in the File Explorer.
Make sure the USB port is active (try another if the flash drive doesn't work). Some USB ports can be disabled for power savings or security. On Windows the first is an Advanced Setting from the screen saver. The second is found in the device manager (Control Panel > System and Security > System for Win7).
I hope this helps.
I bought a PNY 16GB USB Flash Drive to download my music to, but it doesn't DO anything... I am using Windows !0. When I plugged it in nothing happened. Please, I have been trying for hours, HELP!
The flash drive may need to be REFORMATTED. In some cases, the flash drive is pulled out from the USB port incorrectly. That can lead to a damaged Flash Drive.
Always remove Flash Drives by using the EJECT method.
To format the USB Flash drive, go to the File Explorer (the bottom row of Icons on the computer screen showing a manila folder inside a holder) and locate the USB drive by letter, such as drive B,C,D, etc. One of these letters or higher. Tap the corresponding to the USB drive and an option box comes up. Select "Format" (Quick is ok). Once formatted, the drive is ready to accept data once again. If it cannot be formatted, then the USB DRIVE may have sustained damage to the circuit and no longer can be of service.
