20 Most Recent KitchenAid Batch Feed Garbage Disposal KBDS100T Questions & Answers
Don't install auto-start disposal
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
KitchenAid Batch... | Answered on Feb 06, 2019
Check location of leak. If from bottom, replace disposal
Copy following link to repair, troubleshoot and replace disposal:
Add a comment as needed, or repost question with detail
KitchenAid Batch... | Answered on Dec 05, 2018
Use broomstick:
KitchenAid Batch... | Answered on Dec 06, 2014
Check switch. replace switch. If switch checks out, then replace disposal to avoid risk of overheating and in-wall short.
KitchenAid Batch... | Answered on Aug 20, 2014
Use broomstick and see if you can rotate cutter disc
gene
KitchenAid Batch... | Answered on Aug 15, 2014
Replace with new one
Replace disposal
gene
Dont install auto start disposals
Gene
h
KitchenAid Batch... | Answered on Jul 26, 2014
Here is the manual for that model. See the troubleshooting section
http://www.manualslib.com/manual/287637/Kitchenaid-Kbds100t.html#manual
KitchenAid Batch... | Answered on May 26, 2013
Check that voltage is 80% of rating shown on rating plate.
Return unit for warranty
KitchenAid Batch... | Answered on May 22, 2013
Replace disposal with type that uses switch for more reliability
Remove P-trap and clean tubular drain and p-trap
Replace disposal
Turn off circuit breaker, and replace switch
Parts are available at many sources
Copy following link to repair parts, troubleshoot and replace disposal:
Replace disposal
It is possible that themachine does not start off the cycle because there are errors or feedback fromthe inputs. For the program to start up the main program controller mustinitiate the INLET/PUMP MOTOR/DRAIN to workwhen it is commanded .If this does not happen then the voltage at thesepoints must be checked or the faultrelates to no voltage/drive from the controller. This means the controller is asuspect.Check howto remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html If thewater flows then the flow should be good, if not the inlet valve is bad or thereis dirt in the filter. Also check the flow at the inlet of the water line. Whatis most important for the motor to start functioning is that the door switchmust be ON when the door is shut or this will be an error for starting themotor. The water pressure must be good and the spraying must be seen to begood. If there is low pumping or pressure then the spray arms will not turnaround to inject with pressure. If sothe pump must be checked for clogging.To replacecheck this link:http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html Finallyafter the wash the drain valve will be activated, the water is allowed to comein to rinse and then finally the drain valve/pump activated so as to drain offall the water.Make surethat a fault in any of the cycle will relate to the specified action, so checkthe command from the program module and then the executing device be it thevalve or motor or pump. Please check the link below:http://www.espares.co.uk/advice/dishwashers/a/3
KitchenAid Batch... | Answered on Jul 04, 2012
KitchenAid Batch Feed Garbage Disposal KBDS100T Logo
22 questions posted
Top KitchenAid Garbage Disposals Experts
Gene Haynes
markus
markus
Reno Smidt
Reno Smidt
Are you a KitchenAid Garbage Disposal Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Garbage Disposals
Most Popular Question
garbage disposal jammed kitchen aide kwd
  • Garbage Disposals
