20 Most Recent Bosch 15 White Washer And Dryer Pedestal With Drawer WTZ1610 Questions & Answers
what was question ??????????????????????????????????
Bosch 15 White... | Answered on Feb 15, 2015
this error code relates to no turning on to operation, now this can be the motor or the motherboard is not sending the power to the motor or program mode. on an empty load turn the drum round and quickly close the lid and turn on if it comes on then its the motor, ( has a bad spot) now don't ask me how to do this as i don't know i was just told my self. this is from a person who had one of these models.
Bosch 15 White... | Answered on Apr 19, 2014
If your dryer is a condenser type maybe you need to yank out the condenser and give it a good clean. Could not make the model number posted work.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Bosch 15 White... | Answered on Sep 22, 2010
E 06 means slow or no drain//not a easy do it yourselfer machine//you will need to get to the pump might be plugged//for the do it yourself you can get to the back( but this won't be easy) most techs if they know the machine will take front of that takes pratice//anyhow take rear panal of you will see drain pump in there remove tub to pump hose most likely has some items inside//note some bosch washers have small pump drain hose to get water out before you remove pump hose/if it will drain do that first save alot of mess...........(((( check this first))) note some have round cover at lower bottom put pointy item in hole of cover turn to release ( it will turn hard) some also had cleanout behind that cover/ if so check pump from that location much easier then taking back of.....Hope this helped if it did please vote...if you need more help please ask ...good luck
Bosch Washing... | Answered on Nov 25, 2019
Hi , could any know what F67 ERORR CODE FOR . IT KEEP SHOWING ON THE SCRREN MY WASHING MACHINE IS I XX8 BOSCH
Thanks
Bosch Washing... | Answered on Nov 08, 2019
If your model is WFMC3301UC/06, the Main Control Board is: OEM Part # 00660809
Bosch Washing... | Answered on Nov 07, 2019
FROM FIXYA
Sanja Salatic NOV 29, 2009
The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
to fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing.
Bosch Washing... | Answered on Nov 03, 2019
CL indicates child lock has been activated. to deactivate it you need to press and holding the start button for 5 seconds.
Bosch Washing... | Answered on Oct 30, 2019
the electronics lock out during power surges like you would get from brush failure giving e 21 error. you have to access service test prog to reset this, and it is not in public domain.
i do know how to reset it though but difficult to explain on this forum you may find a you tube video if you search online.
Bosch Washing... | Answered on Oct 17, 2019
Hi, I know it's kind of a silly thing but when loading the machine make sure nothing is jammed against the dispenser preventing it from opening. I've run into that a few times and people looked at me like I had two heads but when I showed up to look at the machine,it was loaded like thanksgiving dinner was just over. If that is not the issue then it's either the dispenser itself that is broken or it's not getting power from the board. Either problem will require getting into the door of the machine and running a test program. I would call a local appliance repair company as these tests require the machine to be powered up and specific tools. Hope that helps.
Bosch 15 White Washer And Dryer Pedestal With Drawer WTZ1610 Logo
Popular Tags
6 questions posted
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
bosch wvd24520gb washer dryer runs wash
  • Washing Machines
