20 Most Recent
U-Line ULine BI2115B00 Black Echelon 15" Drain Free Ice Maker with 25 Pounds Daily Ice Production Questions & Answers
Our icemaker makes cubes, but
Have a look at the
manual on page 6 for adjustment procedure.
Also, your leak may be due to a water valve that is not able to turn off 100%. Valve replacement would be necessary. Unplug your icemaker electrical, and empty the ice. Leave the water turned on. If you keep getting water collecting in the bin, you are likely looking at a water valve replacement (not hard at all, just inconvenient).
Clrc02075s
yes turn the rocker switch but you cant use it as a refrig this cuts compressor and all off
I have a U-Line CLR2060 undercabinet ice maker.
The storing compartment is not refrigerated so it will melt away the warmer ambient temperature the faster it will melt . also make sure there isn't something producing heat in the compartment
U line wcm 45 head unit removal.
The thermostat does come through the back of the unit and pushes into a tube attached to the ice mold , I do belive they are still available
Maplin N20FR - damp test meter. I have no
N20FR - Used to measure the moisture level in sawn timber (also cardboard, paper) 6 to 44% on the left hand scale and hardened materials (plaster, concrete and mortar) 0.2 to 2.0% on the right hand scale
4/14/2024 9:12:34 PM •
Kitchen...
Answered
3 days ago
