20 Most Recent
U-Line ULine CLR2160S00 Echelon Series 15" Wide Undercounter BuiltIn Clear Ice Maker With Daily Ice Rate Up To 60 Lbs In Stainless Steel With Right Hand Hinge Questions & Answers
ULine CLR2160S00 was making
Does the ice maker get water? Could the fill line be blocked? I found on my freezer ice had formed at the end of the tube and once I removed the ice it has worked fine since.
Clrc02075s
yes turn the rocker switch but you cant use it as a refrig this cuts compressor and all off
I have a U-Line CLR2060 undercabinet ice maker.
The storing compartment is not refrigerated so it will melt away the warmer ambient temperature the faster it will melt . also make sure there isn't something producing heat in the compartment
U line wcm 45 head unit removal.
The thermostat does come through the back of the unit and pushes into a tube attached to the ice mold , I do belive they are still available
Maplin N20FR - damp test meter. I have no
N20FR - Used to measure the moisture level in sawn timber (also cardboard, paper) 6 to 44% on the left hand scale and hardened materials (plaster, concrete and mortar) 0.2 to 2.0% on the right hand scale
4/14/2024 9:12:34 PM •
Kitchen...
Answered
on Apr 14, 2024
