20 Most Recent 00 2000 Chevrolet Blazer 4.3L V6 Ls Left Driver Side View Door Mirror Questions & Answers
Drivers side Brake light and upper brake light not working on 2000 chevy blazer ls. Bulbs replaced and fuses checked. Still not working
Check the wiring in the area of that particular light. You may have a corroded or broken power wire. Also check the earth wires - usually a black wire.
3/14/2016 7:27:28 PM • 00 2000... • Answered on Mar 14, 2016
SHOWN DTC CODE P0001 & P 0237
P0001 Fuel Volume Reg Ctrl Circ/Open P0237 Turbo Boost SensorA Circ Lo Input Sounds like you have problems in the fuel circuit or fuel sys. for the pressure regulator. If you fix the pooo1 code you may also fix the second code because it is a result of the first one. Ssssssssss
12/13/2015 6:55:20 AM • 00 2000... • Answered on Dec 13, 2015
2answers
Driving down the highway. He said it started losing power so he exited the highway to investigate. When he came to a stop the engine died and the oil fill cap shot off the fill tube.
Check for a blown intake gasket. You can start the engine and put smoke around the intake and see if it sucks it into the leak.
12/3/2015 7:29:00 AM • 00 2000... • Answered on Dec 03, 2015
I have a 2000 blazer. it idles fine but when i give it gas while driving it wants to choke out
Blazer bogs down while accelerating - Blazer Forum - Chevy Blazer ...
blazerforum.com > ... > 2nd Gen S-series (1995-2005) Tech
Jul 28, 2009 - Hello, I have a 1998 Blazer which bogs down when I accelerate. TheBlazer will pick up speed if I let up on the accelerator and gently press the ... Hard shift, then bogs down...lack of power Mar 1, 2012 Bogs down when turning on heat Dec 31, 2011 Won't accelerate after driving for awhile, please help. May 29, 2011 Problems with bogging down and hesitation. Sep 16, 2009 More results from blazerforum.com
11/29/2015 8:55:42 PM • 00 2000... • Answered on Nov 29, 2015
How do I install a remote starter. I a mechanic by trade and I haven't installed one yet.
If you want it inside the car ,run 2 wires inside the cabin or pick up power at the fuse box ,mount a push button to the best place you can find then run a second wire to the small wire on the starter motor then wire the switch power one side , starter wire the other side.
11/17/2015 3:49:42 AM • 00 2000... • Answered on Nov 17, 2015
How to replace ABS wheel sensor
They just unbolt at the brake caliper and a push in plug up the wire.
10/4/2015 3:03:57 AM • 00 2000... • Answered on Oct 04, 2015
Getting codePO446 & light came on after replacing fuel-pump, filter & gas cap on my 2000 Chevy blazer
Check for any kinked or blocked hoses to the EVAP system as they may have been disturbed during pump replacement.
9/10/2015 4:20:42 PM • 00 2000... • Answered on Sep 10, 2015
How do I install a remote starter. I am mechanic by trade and I haven't installed one yet?
They are not very difficult to install. Just follow the directions and you should have a wiring diagram for the vehicle your working on, just makes the install faster.( use good name brand and proper wiring techniques)
6/10/2015 5:16:02 AM • 00 2000... • Answered on Jun 10, 2015
Missing on #5 cyl.
Hi . Hard to say. how do you know its the #5 plug? Possible cause is ? 1 faulty spark plug? 2 Or a plug lead? 3 or a valve burned. I'd change them all . start with the cheapest option . failing that if you can take it to a auto electrician he will find the problem ? good luck.
3/2/2015 5:43:52 AM • 00 2000... • Answered on Mar 02, 2015
2answers
My transmision is slipping or feels like its slipping and im low on fluid but shows no sign of leaking??
First thing is to top the fluid up to the full mark while the vehicle is running at normal running temp. Then try to drive it if it's still slipping you have a problem with the transmission.
2/25/2015 3:55:05 PM • 00 2000... • Answered on Feb 25, 2015
Knocking from the front of the motor slight minute dirt or shavings when oil was changed. transmission has been giving me a problem going ino 2 but its smooth just the noise
Check the belt tensioner, they stick and get sand in them. If you had shavings in the oil, you lost a bearing in the motor, sometimes a can of ZED or Slick 50 type additive can help for a while. Usually not a long while though.
2/16/2015 3:52:30 AM • 00 2000... • Answered on Feb 16, 2015
I pulled the drivers seat side plastic to reconnect the lumbar switch which had fallen in. the plastic pieces that hold the switch to the plate were broken so I took the switch apart to epoxy the shel
That would be the first thing I would check. Your fuse door should tell you which fuse is responsible for what, and what amperage it needs.
2/14/2015 6:12:07 PM • 00 2000... • Answered on Feb 14, 2015
Why won't my gray exterior button/switch open the rear hatch door on my 2000 Chevy Blazer LS? I push the gray interior button for it and hear a clicking noise and then it will open with help from some
if the opening mechanism is actively assisted with electric motors, then they may not be working, check your fuses
8/11/2014 4:07:03 AM • 00 2000... • Answered on Aug 11, 2014
Codes of 0174 2x,0300,1509 is this clogged injectors
Might check your 02 sensers
1/21/2014 9:01:42 PM • 00 2000... • Answered on Jan 21, 2014
2000 BLAZER WONT TURN OVER ERROR CODE PO446
not turning over i assume means engine starter not engaging the flywheel when key is move to start position if so, then locate your starter apply 12volts to the small wire at the solenoid if the starter turn over then your problem could be your neutral safety switch to check turn ignition sw to on then shift your shifter to neutral and try to start. if it start replace safety sw. if not check fuses and starter relay. your starter could be at fault too if starter fail to turn over when power is applied directly to small wire at the solenoid.
11/6/2013 3:58:44 AM • 00 2000... • Answered on Nov 06, 2013
2answers
How to reset automatic sliding door on chevy venture van
The rear side door actuator control modules monitor the power sliding door positions at all times. Whenever the battery positive voltage supply to a rear side door actuator control module has been removed or the on-board diagnostics have been activated the power sliding door system(s) must be re-initialized. Re-initialize the right or left power sliding door systems using the following steps:
  1. Turn the ON/OFF switch for the power sliding door system to be re-initialized to the OFF position.
  2. Manually open the power sliding door completely.
  3. Manually close and latch the power sliding door.
  4. Turn the power sliding door ON/OFF switch to the ON position.
  5. Open the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
  6. Close the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
9/9/2022 4:43:40 AM • Chevrolet... • Answered on Sep 09, 2022
Drum brakes 1998 s10
What is the question?
11/25/2018 2:32:16 AM • Chevrolet... • Answered on Nov 25, 2018
Torque specs 05 Chevy Silverado 1500 4WD front hub assy and axle nut
165 ft lbs
11/25/2018 2:26:57 AM • Chevrolet... • Answered on Nov 25, 2018
I tried the solution for the ast ultra remote car
It is still immobilized through the alarm system then.
8/29/2017 6:20:45 AM • Chevrolet... • Answered on Aug 29, 2017
00 2000 Chevrolet Blazer 4.3L V6 Ls Left Driver Side View Door Mirror Logo
15 questions posted
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
ZJ Limited
ZJ Limited
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Chevrolet Vehicle Parts & Accessories
Most Popular Question
install remote starter am mechanic
  • Vehicle Parts & Accessories
