20 Most Recent
Husqvarna 125bvx Hand Held Blower Vac Questions & Answers
Husqvarna 125 BV how to adjust carb screws, yes I can turn them but how to start all the way in on both screws
I would think that the screws have limiter caps, so you cannot turn them all the way in.
1) put both screws at the maximum you can turn them out
2) start and warm up the engine
3) at idle speed, turn the L needle in till the engine speeds up (by itself) and then starts to lower rpms.
4) from that point, turn the L needle back out till engine raises and then lowers. Leave the screw in a setting that the engine sounds a little rough
5) use the same procedure with the H screw (at full throttle)
6) now throttle up from idle
does the engine pick up quickly? settings are good
does the engine stumble and then finally begin to pick up?
Then turn the H out about 1/4 turn. If needed for rough but smooth running, turn the H out again another 1/4 turn.
*Please Note: 2cycle engines should ALWAYS sound just a little rough at full rpms. NEVER adjust a carburetor so that the engine 'screams', you will not have an engine for very long at that condition. I’m happy to assist further over the phone at
https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Husqvarna problems
No, it is a return line to the tank from the primer. It sounds like the hoses are reversed. The fuel should flow from the tank via the main fuel line (with the filter)( sometimes the main line is smaller than the return line) to the carb, fills the carb then to the primer bulb, and from the primer bulb back to the tank. With just enough fuel in the tank to cover the fuel filter start pressing the primer bulb. Check for fuel coming out the short hose into the tank. If instead the bubbles come out the filter and the primer goes dry try reversing the lines at the carb and/or the primer bulb and try again until you get the proper flow pattern.
Change fuel lineshusqvarna 125bv
cut the new fuel line down to 1/3 it dia size about a 1/2'' long slide a stiff wire threw the hole and out threw the gas cap opening slide the hose over the wire and pull it back till the hose comes threw put the fuel filter on and pull it into pace
How to replace fuel lines
i take the new piece of hose cut it down to 1'3 its size about 1/2 long then feed a stiff wire threw the hole and out threw the cap opening slide the hose over the wire and pull it back when the hose pops threw remove the wire and pull the hose threw pt the fuel filter on the end before pulling that one all the way threw
