20 Most Recent Mtd Cub Cadet 48 In 22 HP Kawasaki Engine Dual Hydrostatic Z Force S Zero Tur Questions & Answers
Sounds like seat safety switch.To check switch use a piece of wire unplug seat switch under seat. stick wire in both sides of plug to complete circuit and try to use mower. If works replace switch.
Mtd Cub Cadet 48... | Answered on Sep 05, 2014
That was happening to me, until I realized I had to have both steering bars pulled back toward me all the way before the mower would start. I'm not sure why it started doing this, but you can try pulling both bars back as far back toward you as you can, and then see if it will turn over for you. I hope this helps.
Mtd Cub Cadet 48... | Answered on Jul 17, 2014
You may want to try to find a battery with a stronger amperage rating. Even if the battery passes if it is borderline for starting it new it may not be strong enough even if it's still okay for it's battery type.
Other causes:
A worn starter can cause this issue. If a few of the coils shorted the starter will work but require much more current to do the job
A bad relay/solenoid to the starter that doesn't allow enough current to go through can cause this.
Valves out of adjustment... especially on some Briggs and Stratton engines, it's a known issue that if the valves need adjustment the motor can require a lot of energy to turn over and can cause constant hard starts.
Mtd Cub Cadet 48... | Answered on Nov 14, 2013
SOUNDS LIKE THE HI SPEED JET IS CLOGED UP
Mtd Cub Cadet 48... | Answered on Nov 11, 2013
Check for water in the fuel tank. Good Luck...
Mtd Cub Cadet 48... | Answered on Oct 07, 2013
there is a oil pressure switch on the oil filter hosing did you knock the wire off when changing the filter?
Mtd Cub Cadet 48... | Answered on Jun 05, 2012
I don't know. Having said that, I would sugg3est you smack the bolt a good single solid blow then try RH again. BTW - Lefty Loosey ... Righty - Tighty.
I would expect it will be on very tight ... you might want to spray a product called Liquid Wrench or other penetrating oil on the bolt and let it sit for a while before you try again.
Try not to break it ... but if you do ... it is not the end of the world. You can drill it and use an "easy out" to remove the broken stud from the hole. Get help on easy out and drill size before you start if it gets to this point.
Mtd Cub Cadet 48... | Answered on May 02, 2011
You might be able to find what you are after here >> https://www.mtdparts.com/en_US/ari-partstream.html <<
Regards
Geoff
Mtd Garden | Answered on Jan 07, 2020
not adjusted correctly -wrong cable -wrong belt on deck
Mtd Garden | Answered on Oct 08, 2019
Check with SearsPartsDirect.com if they cannot answer try eReplacement Parts.com
make sure the vent in the gas cap isnt plugged up. test by loosening it a bit to see if it cures your problem
Mtd Garden | Answered on Oct 07, 2019
Mtd Cub Cadet 48 In 22 HP Kawasaki Engine Dual Hydrostatic Z Force S Zero Tur Logo
Popular Tags
19 questions posted
Top Mtd Garden Experts
dannydoesita
Joseph Mueller
Joseph Mueller
p38arover
Level 1 Expert
Are you a Mtd Garden Expert? Answer questions, earn points and help others
View Most Popular
Mtd Garden
  • Mtd Garden
Most Popular Question
mower die when release park brake
  • Garden
