20 Most Recent
Mtd Drive Belt 42" Questions & Answers
Want to eliminate AC compressor from belt
Some vehicles that have A/C as optional had pulley arrangements that allowed for with/without A/C routing. You just needed a shorter belt. Newer vehicles all seem to have A/C standard and so it is more difficult to bypass the compressor on many of these. If you provide the manufacturer, year, model, engine size, and 2WD/4WD/AWD, we can research and address the question better.
My MTD riding mower is
normally sign of a failing hydrostatic transmission. if your mower has one, start looking for a new one, mower that is as a new tranny will cost more than a new mower.
My 42 mtd is chugging when i put in forward
Don't know if this is your problem but here is what happened to mine..
My lawn tractor is about 10 years old. It has been generally quite reliable. However I was mowing with it one day and after 15 minutes or so it started hunting and then quit. After a few minutes it restarted and ran for a further 15 minutes. This time I disconnected the gas line after the fuel filter and nothing came out. I removed the filter and blew through it and it was clear. But no gas came out of the gas line till I pointed it downward then got a good flow. Reassembled and drove for a few more minutes and quit again. Checked the spark - good. I removed the gas line after the filter again intending to blow some air into the carburetor to clear any obstacles there except - no gas from the line. I removed the gas cap and out came the gas. The problem was the pinhole vent on the cap was plugged and not allowing air into the tank to replace the gas being consumed. Cleared that and solved the problem! Hope it helps someone else save $150 or whatever it costs to take it into the shop!
How do i change the drive belt on my L 130 ?
Remove the mower deck first.
Remove the electric PTO clutch assy.
Disconnect the clutch spring as to remove the tension on the drive belt.
From there it a simple matter of removing the belt from the pulleys. Depending the belt retainers you need to them too.
