20 Most Recent Toro LX423 20HP Lawn Tractor 13AX90RS848 Questions & Answers
I have a small incline
From what you describe, it sounds like you could have a faulty throttle return mechanism, a faulty variable drive, bad brakes, or a combination of these faults. The variable drive is not supposed to exceed 5.5 mph speed regardless of the terrain if working properly. The fact that you had to stand to put all your weight on the brakes in order to stop definitely is indicative of the need for servicing the braking mechanism, despite whatever else may also be at fault.
1/20/2018 6:13:03 PM • Toro LX423 20HP... • Answered on Jan 20, 2018
How do i get my tractor to start? all it does when trying to start it is clicking
Sounds like a bad solenoid in the starter.Needs expert help.
3/14/2015 7:45:59 PM • Toro LX423 20HP... • Answered on Mar 14, 2015
0answers
0answers
0answers
Fuse mower
Be the first to answer 8/26/2013 3:16:24 AM • Toro LX423 20HP... • Posted on Aug 26, 2013Be the first to answer
0answers
Lx420
Be the first to answer 7/11/2013 7:53:26 PM • Toro LX423 20HP... • Posted on Jul 11, 2013Be the first to answer
0answers
I turn the key nothing happens
First check voltage at battery. Should be 12.6 volts. Next check fuse. If problem has not been found you will need a test light and knowledge of the wiring system to pinpoint the failed switch.
11/19/2012 3:47:38 PM • Toro LX423 20HP... • Answered on Nov 19, 2012
0answers
How do i by pass starter to crank untill I get it to the shop
just use a pair of jumper cables fro your car and go direct to the starter it will make it harder for a shop to fix it if you move stuff around they would need to put it all back the find the original problem
8/10/2012 12:59:37 AM • Toro LX423 20HP... • Answered on Aug 10, 2012
How to replace bottom bearing/seal on 20 hp kohler vertical shaft
You need to remove the engine and take out the bolts holding the upper and lower crankshaft housings together.
5/25/2012 12:34:33 AM • Toro LX423 20HP... • Answered on May 25, 2012
Toro LX423 20HP Lawn Tractor  13AX90RS848 Logo
39 questions posted
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
View Most Popular
Toro Garden
  • Toro Garden
Most Popular Question
lx420 won 39 t turnover checked
  • Garden
