20 Most Recent Toro Power Lawn Mower Questions & Answers
Black carbon fouling on the plug is a sign of the engine running too rich, start by replacing the air filter and plug and try again.
Toro Power Lawn... | Answered on May 02, 2018
Request the drive belt diagram directly from Troy-Bilt.
Toro Power Lawn... | Answered on Apr 03, 2018
check the spring on the shifter
Toro Power Lawn... | Answered on Feb 07, 2018
Take the mower back to the shop and request that it be returned in running condition.
Toro Power Lawn... | Answered on Oct 27, 2017
FIXYA can not fix broken parts , SORRY
Toro Power Lawn... | Answered on Oct 21, 2017
uncoiling the spring may be the only way to get it reconnected.
Toro Power Lawn... | Answered on Sep 28, 2017
There is a large black plastic nut at the end where the cable attaches to the mower transmission. Turning it clockwise tightens the cable (engaging traction bar is tighter) and counter-clockwise is loosening the drive. If the cable is a little too long, you have to tighten it more.
check and be sure the blades are sharp. if the blade gets a rounded edge it wont cut properly and will bog down trying to cut.
Toro Power Lawn... | Answered on Aug 15, 2016
gov. rod hooks to the hole in the top of the butterfly. the spring hooks to the carb and the front of the engine on the metal tab.
Toro Power Lawn... | Answered on Aug 10, 2016
could be dirt in the carby , blocked fuel filter or lack of adjustment in the accelerator cable
I will go for a cable adjustment as they slip under the clamp on the carby bracket when the throttle is pull wide open
Toro Power Lawn... | Answered on May 31, 2016
no its not. I work at a toro dealership.
Toro Power Lawn... | Answered on May 19, 2016
Toro has your manuals here depending on year of purchase. If they don't mention the gap, I would use to the contact page to ask.
https://www.toro.com/en/homeowner/walk-behind-mowers/22-personal-pace-20332
22 56 cm Personal Pace 50 State 20332
Toro Power Lawn... | Answered on Apr 14, 2016
Their's a bowl under the carburetor ,remove gas from tank or pinch gas line and remove ***** under bowl and gas will come out,clean bowl and reinstall and start it up,Trash gets in their,need a inline filter to stop it.Lowe's has them,3 dollars.
Toro Power Lawn... | Answered on Mar 16, 2016
Did you follow instructions and put it into gear after motor start? If you did and still no go, transmission not working- since new take it back and have it replaced.
Toro Power Lawn... | Answered on Oct 29, 2015
Toro Power Lawn Mower Logo
486 questions posted
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
roeb
Marvin
Marvin
Are you a Toro Garden Expert? Answer questions, earn points and help others
View Most Popular
Toro Garden
  • Toro Garden
Most Popular Question
13wx78ks011 drive belts diagram troy
  • Garden
