20 Most Recent Fisher Price Disc for Digital Arts and Crafts Studio Questions & Answers
Finally able to install...Copy the contents to the CD into your hard drive, edit the Options.ini file so that it reads ShowVideoAdapterDetails=1. It will allow you to bypass the video memory check....Hope this helps
Fisher Price... | Answered on Mar 11, 2016
These are the things that I would recommend:
1. Check your anti-virus and make sure that it's updated. It's possible that your laptop has been infested by a virus and this is causing your software to malfunction
2. If your anti-virus is updated, then try uninstalling it and installing your software again.
3. If none of this works, then you really have to go to the computer shop and have it checked.
Fisher Price... | Answered on Jan 21, 2014
I had the same problem of the console not being recognised and the software failing to install propperly. I run windows 7 professional 32 bit O/s and after many hours of the console not being recognised I came across a link at the fisher Price website. I downloaded the software as it describes and bingo...up and running.
hope this helps
http://service.mattel.com/us/faq_results.asp?contentidlist=62056&faq_id=62056
Fisher Price... | Answered on Mar 16, 2013
Fisher Price Music box: to open, remove the four screws from the bottom, open the two parts as wide as possible without using too much force. Using a small flat blade screw driver, insert between the red cover and white top where the wind up knob is located. Pry the red bottom out far enough to allow the ring surrounding the knob to slide under the red bottom. The box is now open.
After repair, and re-assembling, make sure the wider part of the wind up stop wheel faces the front of the player, otherwise the wind up knob catches and slows the mechanism.
Fisher Price... | Answered on Nov 22, 2019
Contact them direct for repair. The Contact link is at the bottom of the page.
https://www.fisher-price.com/en_ca/index.html
Fisher Price... | Answered on Nov 05, 2019
As we can not fully see the damage my best bet would be to take it to a local "Mens Shed" where I'm sure they can fix it for you.
Fisher Price... | Answered on Jun 06, 2019
Check power supply and switch operation.
Fisher Price... | Answered on May 28, 2019
Contact Fisher Price directly to request the manual.
Fisher Price... | Answered on Apr 18, 2019
my grandsons broke their mother's (and aunts') FP music box.
There was almost no sound
The teeth are simply a wind-up music box set, connected to a rod that transmits the vibrations to the diaphragm under the pseudo-tone-arm. I was able to fix by placing a cotter-pin on the rod in the arm at or near the junction and then trim with wire cutters to the correct size.
I checked the diaphragm first by tapping it through the arm/table connection.
Fisher Price... | Answered on Apr 06, 2019
Fisher Price Disc for Digital Arts and Crafts Studio Logo
22 questions posted
Top Fisher Price Toys Experts
Marvin
Marvin
NOEL
NOEL
yobo007
yobo007
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
View Most Popular
Fisher Price Toys
  • Fisher Price Toys
Most Popular Question
fisher price digital arts crafts studio
  • Toys
