20 Most Recent
Samsung S3500i Cell Phone Questions & Answers
S3500i hard reset
first shut down it then keep holding #,3 and the green button for 3 seconds then while pressing on them power on the phone
Hi first I would like to thank you inadvance your
I assume that you can at least see the display like texts or images on the screen even if it's dark. There four things which can cause this, first the display cable (flex cable), second the display connectors on the display or on the board of the mobile/phone,third is display ic and the fourth is the display itself.
To troubleshoot this, it's a must to open apart the set, you'll need appropriate screw drivers and spares like display and flex cable.
Open the case, disconnect the terminals of the display flex cable from both the display and from the board, do some cleaning with alcohol/spirit/ipa solution with a soft brush, and again reconnect them after it's dried. If this isn't successful, go to next step.
Next replace another cable (display) and check if you can see the light on the screen or not. Again there's no light? Next step...
Connect the other display (should be a working display of the same model and type). If the problem goes, then your solution is replacing the display. If not the display ic which only professionals and trained technicians can handle.
Hope this helps.
Good luck.
Thanks for using FixYa.
M using s3500i n not
Yo! I will have to direct you to a website where you can download anything for your phone. please follow the links below..
www.download.com
getjar.com
waptrick.com
4shared.com
Using samsung s3500 mobile..when i
Probably, when a memory card is damage or corrupted,the phone fails to read the card and its content. The games and application installed on your memory card might be the problem thats why you phone restart.
Here's the Solution :
* Reset your phone by typing this code on your homescreen *2767*3855# ,this method will restore settings into default as well as easing all contents including contacts,messages etc. So before doing this thing,be sure to back up all important data first.
* Format your memory card on pc or in your phone and try to load another games and applications.
Remember that all file you download should be placed in memory card and not on the phone memory.
Hope this solution helps...thanks
Hi........
in ma samsung cell,when i
This CODE below is for erase the old security code and reset the all mobile settings to its original settings:
*2767*3855#
And about the applications installation on your mobile...use SAMSUNG PC STUDIO program
from www.samsungmobile.com
and use it to connect your mobile to your PC ,and install applications like :dictionary and other applications.
I want samsung default reset pin for reset
Hello and Welcome to FixYa!
If you haven't changed reset pin code before then Default reset pin
code for samsung is 00000000 (eight
zero's)
I hope it works.
For further assistance i am here to help.
Thank you for using FixYa!
Concerned: Angel Bird
What is the default phone code of Samsung S3500i
You can get the unlock code through online..........i will suggest the website unlock-zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
I cant see any font
Hi
Switch off the your mobile and switch on again take the battery out also and again reinsert it.
besides please make sure that your battery is fully charged.
Regards
Vipin
How will lock my Phone
if you want to automatic key lock , you can find the option under " menu>settings>phone settings>automatic key lock"
for security key lock "menu>settings>phone settings>security key guard"
