20 Most Recent
Hannspree HH251HP 25 in LCD TV Questions & Answers
Hannspree 25" LCD tv will not work with new xfinity Comcast remote
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
12/9/2017 12:41:28 PM •
Hannspree...
Answered
on Dec 09, 2017
Dark screen
May not be all of a back lighting problem. The circuit board that controls the screen may be faulty or just a bad connection on the ribbon cable that connects to the board. .
1/5/2014 11:06:43 PM •
Hannspree...
Answered
on Jan 05, 2014
Hannspree HSG1074 LCD HDTV
The weight of the Hannspree HSG1074 24 inch LCD HDTV is approximately 8.8 pounds (4 kg) without the stand. However, the weight may vary slightly depending on the specific model and any additional accessories that are included with the TV. If you need more precise information, you may be able to find the weight listed on the product specifications page on the Hannspree website or in the user manual that came with the TV.
4/26/2023 4:59:13 AM •
Hannspree...
Answered
on Apr 26, 2023
Hannspree 42 lcd right side is showing ghost picture
The issue you are experiencing with your Hannspree 42 LCD TV could be caused by a few different things, such as a loose cable connection, a faulty T-con board, or a defective panel.
Here are a few steps you can try to troubleshoot the issue:
- Check the cable connections: Make sure that all the cables connected to your TV, especially the ones connected to the right side of the TV, are firmly plugged in.
- Power reset: Try turning off your TV and unplugging it from the power outlet for at least 10-15 minutes, then plug it back in and turn it on again.
- Swap inputs: If you are only experiencing the ghosting on one input, try swapping the input with another one to see if the issue persists.
- T-con board: If none of the above steps resolve the issue, it is possible that the T-con board is faulty. The T-con board controls the timing of the image displayed on the screen and is often the culprit of ghosting issues. A technician can diagnose and replace this board if necessary.
- Panel: If the above steps don't resolve the issue, it is possible that the LCD panel itself is defective. This is less common but can happen over time. Unfortunately, replacing the panel can be costly and may not be worth it on an older TV.
If none of the above steps resolve the issue, it may be best to contact a qualified technician to diagnose and repair the issue.
2/28/2023 1:47:00 PM •
Hannspree...
Answered
on Feb 28, 2023
How to Program hannspree remote to hannspree tv
To program a Hannspree remote to a Hannspree TV, first turn on the TV and then press and hold the "Code" button on the remote until the LED light turns on.
Next, enter the four-digit code for the TV using the number keys on the remote. If the TV turns off, press the "Code" button to save the code. If it doesn't turn off, try another code until you find one that works.
If you cannot find the four-digit code for your Hannspree TV, you can try using the code search feature on the remote. To do this, follow the steps for programming the remote but instead of entering a code, press and release the "Code" button and then press the "Power" button repeatedly until the TV turns off. Then, press the "Code" button to save the code.
If you are having trouble programming the remote, make sure you are aiming the remote directly at the TV and that you are not too far away. Also, check that the batteries in the remote are fresh and properly installed.
If you accidentally program the remote to the wrong TV or if you want to program it to a different TV, you can reset the remote to its default settings by pressing and holding the "Code" button for at least three seconds until the LED light turns off. This will erase any previously programmed codes.
2/14/2023 10:49:36 AM •
Hannspree...
Answered
on Feb 14, 2023
Hannspree TV tuning from aerial problem.
do you mean if you hooked up the tv with the aerial antenna can not get any channel? ok if just a white raster only and doesn't scan or tuned even manually and auto search, the cause is bad tuner.
3/10/2022 6:57:09 PM •
Hannspree...
Answered
on Mar 10, 2022
How do i factory reset hannspree sv32amub tv
To do a factory reset, you have to enter its Service Mode. If you wish to get some details; check the sites linked here.
https://elektrotricks.blogspot.com/
https://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important
Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in by Webview with mobile or by desktop. Mobile View has no search box.
8/3/2021 2:40:08 PM •
Hannspree...
Answered
on Aug 03, 2021
