20 Most Recent
Ricoh Aficio 1515F Plain Paper Laser Fax Questions & Answers
Error message -using handset (no handset on the
If this appear for the first time see the follow, if this started to appear after a time of usage you will need to call a Ricoh technician, sorry but i cannot gain some help in this type of problems.
see do you use a cord with two wires or four for Ricoh when using some telephone centrals like a Panasonic it's better to use a two wired cord for the line, if this still do not help, you will need to call the telephone central technician to set the line for the Ricoh fax.
Machine is saying that there is a paper jam. We
when you will open the right cover see inside on the bottom has an black part which you can shift it toward the opened cover in the middle have one sensor in form of a pawl or little black finger see do is movable easy or it stack in one position, if this is good than see in the upper part has a blue piece of plastic open it toward you and see do here have some little part of paper sheet in the middle, if and this is OK remove the paper tray by the follow method:pull it toward you to the maximum you can then shift it up in some angle of 25-30% and pull it toward you then the tray should be out (you will return the tray by same way but in inverse procedure follow) when you will pull it out see do have some paper sheet inside if and this do not help then you will need to call a technician
regards
