20 Most Recent
Ricoh Aficio 1035 Copier Questions & Answers
Sc 541 power off on
sc 541 is a fuser error. you have to reset the code. here are the steps to follow.
press clear mode button once, clear mode button is the yellow one
press 107
press and hold clear/stop red button until you see the screen changes to copy sp mode written.
press copy sp on the screen and off and on the machine
it should reset the code.
I HAVE AN ERROR SC 322 WHEN i GO TO PRINT RICOH 1035
Error Code SC322:
1st laser synchronization error
The 1st laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Possible Causes:
+ Poor I/F harness connection between the laser synchronization detector board and the LD unit.
+ Laser synchronization detector board out of position and angle of reflection not correct
+ Laser synchronization detector board defective LD unit defective
Not sure what your expertise is on this, but unless you know how to service the machine yourself, this one is going to require a service call...
There have been instances where toner drops onto the LD Unit and creates problems like this. About a month ago I replaced the Laser Synch. Detector Board in a 1045 for this exact problem and error code.
I'd start by cleaning up any toner on the LD unit, and re-seating all the electrical connectors on the laser unit. If that doesn't clear things up, it's probably one of two things, the LD Unit or the Synch. Board. I'd lean more towards the Synch. Board myself, but you never know...
Can not find ip address on richo 1035. I tried to
Connect the machine to a router or a switch with a network cable.
In used mode, under network settings - set the machine to DHCP, so it will get an IP adress from the switch/router.
Print out a network status page, and see if you've got an IP adress.
In the command window on your PC type: ipconfig/all and see the IP adress of your computer. Compare it to the adress the machine got from the router/switch and see if they are almost identical apart from the last digits.
Install the driver, and install the printer using device name, and you should be good to go. Or you can set the IP you got from the switch/router as a static adress, and install the copier using the IP adress.
Ricoh 1035 laser problem
sometimes
the plastic of the laser is turned by the heat proves to relax and to fit the
screw that holds the laser unit that is of the side of the drum while it raises
a millimeter with a screwdriver, this sometimes works.
Verifies that the glasses and mirrors well
be positioned correctly.
Other
Poor connection between the laser
the LD unit.
out of position
defective
LD unit defective
Back to back not working
Do you mean your duplex unit is not working on the right side of copier?If so, check your door interlock switch where the duplex unit closes up against the copier.If it is bent or not making contact the oper. panel will not let you select duplex.
SC329-00
HOPE YOU SPEAK ENGLISH the error is due to the laser unit malfunction..after memory clear usually..you need to press the yellow clear button then 107 then hold down the stop/cancel button for 5 secs till the screen changes.. then copier sp section 2 drum then look for laser pitch beam adjustment you need the 400dpi and 600dpi initialisation to be done.. this should clear it then turn off the machine and wait 10 secs and turn back on.. hope this helps ..Adios
Sc 305 dsc 224
The error code sc 305 is a charge corona wire cleaner error. Has the pcu or charge corona assy been replaced or removed for any reason?
How to scan documents and save them as JPG Format ...
On some copiers, there is an option to scan as JPG. Press the Scanner function key on the left, and look for a button on the screen that says something like "Scan as file type." Press this button, and if that copier can scan JPG files, you should see the option there. Otherwise you might have to scan as TIFF files and then use a program like Microsoft Office Picture Manager to convert them to JPG images.
Sc 390 problem
could be bad developer powder or is depleted in developer unit. toner density sensor is bad. connector in back were unit slides in broken. this code means not seeing developer unit not install in copier. could be bad board. this copier is old i would replace for a newer one if you can do this.
Service code sc546 what do we need to do to fix
Try to go into service mode to reset the code...
Clear yellow botton
7
then press and hold the red stop botton till the display changes and then turn the main Power switch Off then back ON... You do not have to do any thing in service mode, just get to that display.... Don't change anything unless you know what you are doing. sc546 has to do with the fixing unit. You may be able to reset it.
Used Toner Bottle Full Ricoh Aficio 1035P
The used toner bottle is not actually a bottle at all. Not sure what you emptied, but it sounds like the actual toner bottle itself. The waste toner is contained with in the transfer belt unit. When you open the right side cover, this is the unit that is attached to the door. It is a brown belt that provides transfer of the image to the drum and separates the paper from the drum. Remove this unit by locating the release levers on either side of the transfer unit (push both of them towards the machine). After removing, you will need to actually take the belt unit off of the transfer unit. To do this, remove the two tension springs on either side, and then take a small flat bladed scredriver and release the clips that hold it down (you will see when you get started). Once you get it off, you will see the long blade that actually scrapes the toner off the belt. Dump the waste toner out this end. You will need to shake it pretty hard. A better (and cleaner) option is to vaccum it out using the crevace tool on you vac. Just make sure you completely empty it. Now....do everything in reverse.
Hope this helps,
Chad
Reset error code
press the orange key for say three times and press '107' and place your hand on the 'clear/stop' key for about thrre times .
themachine will take you tothe system sp .
turn off the machine and tuen it on after about A MINUTE .
THANS
