20 Most Recent Flukers 5.5" Repta Clamp Lamp with Questions & Answers
Kicks out breaker
Have you replaced the unit...I bet the cord inside the socket is shorted...If you are capable ....unplug the light unit and disassemble the plastic or ceramic or metal socket. Unscrew the wires from the terminals and remember which terminal goes to which wire ...the power / hot side is usually indicated by a GOLD / Brass terminal. The common side is silver. Cheaper sockets make no distinction. So mark 1 side with a marker...simple. Another good thing to know is the receptacle that you plug it into...the larger grounded side is the "common" side of the receptacle. and the Hot / POWER side is the smaller prong.
5/12/2014 12:26:21 AM • Flukers 5.5"... • Answered on May 12, 2014
2answers
Getting rid of lizards on my patio
Best Ways to Get Rid of Lizards 1. Egg Shells: Lizards will leave the place because the odour of eggs will make lizards assume that there is another organism present in the premises. Keep some eggshells around the corners of your house, doors, and windows. 2. Coffee Powder This is a very effective method to get rid of lizards. Combine tobacco and coffee powder and make balls. Keep the prepared balls on every corner of the house and the places where lizards hide the most. After eating these balls, they will either die or move away from your house .3. Garlic Lizards cannot stand the smell of garlic. This remedy may sound weird to you, but hanging some garlic cloves around your house will keep the lizards away
  • Alternatively, you can place some garlic cloves in the corners and the entrances of the house or spray garlic juice in the lizard-prone areas.
4. Pepper Spray Pepper spray irritates lizards. This remedy will make them run away. Prepare a solution by mixing crushed black pepper and water. Spray this solution all around the house, in kitchen racks, under the stove, fridge and tube light corners. 5. Onion Onion contains sulphur compounds which are responsible for bad odour. Lizards can't tolerate the pungent smell of onion. Hang some onions around all the doors, windows and all the other possible entrances. Or else, keep some onions in the areas encroached by the lizards. This creepy reptile will leave the place soon. 12 Simple Home Remedies to Get Rid of Lizards
6/19/2021 6:16:07 AM • Reptile • Answered on Jun 19, 2021
Types of snakes
It depends..... white diamonds make it a California King Snake. Dark brown to black chain like make it a Diamond Backed Water Snake. Or if it consists of a series of diamonds with an outer frame of white, an inner frame of dark brown and a mottled pattern in the center and a rattle, it's a Western Diamondback....... Where do you live?
7/14/2019 10:23:27 PM • Reptile • Answered on Jul 14, 2019
My southern alligator lizard burrowed under a rock in its habitat and doesnt come out. Is it sick or is this normal?
Sounds like normal behavior as they do like to hide. Unless he or she does not come out to eat or drink then I would consult a vet. Is there any possibility that you may have a pregnant female? Has there been any change in conditions in your habitat or home? Lizards do not adapt well to changes at times and will hide.
4/24/2019 12:49:29 AM • Reptile • Answered on Apr 24, 2019
Rearrange the word dread
adder
3/20/2019 5:05:43 PM • Reptile • Answered on Mar 20, 2019
Why are some snakes the same kind but some are venomous and some are not?
Hello, Taylor - In case you don't realize it, Fixya.com is a website intended for asking and answering questions on how to go about REPAIRING THINGS. If you reside where there are public libraries, I suggest you locate the library nearest you and visit it when it is scheduled to be open. A librarian can help you find answers to all your snake questions. Best wishes.
10/8/2018 4:50:26 PM • Reptile • Answered on Oct 08, 2018
What do snake eat
Anything that moves.
7/31/2018 9:18:12 PM • Reptile • Answered on Jul 31, 2018
I think my iguana has a broken arm
3/24/2018 11:30:37 AM • Reptile • Answered on Mar 24, 2018
What snake is black with yellow stripes?
The Plains garter snake has either an orange or yellow stripe down its back and distinctive black bars on its lip. The stripe normally starts at the head and continues all the way to the tail tip. Lateral stripes are located on the third and fourth scale rows and are normally a greenish-yellow color. q677347_252478_westernribbon_big-fegsgavz0rqgqrigr1jhdrvj-1-0.jpg Plains garter snake
3/24/2018 11:23:20 AM • Reptile • Answered on Mar 24, 2018
Kind of snake with black body whitestripes dimaion?
Eastern kingsnakes are large -- 36 - 48 in (90-122 cm) -- shiny-black, smooth-scaled snakes with white or yellow chain-link bands that cross the back and connect along the sides. Because of this pattern, this species is also referred to as the chain kingsnake. mllateralismo-fegsgavz0rqgqrigr1jhdrvj-1-0.jpg lgcaliforniaebp-fegsgavz0rqgqrigr1jhdrvj-1-2.jpg
3/24/2018 11:20:49 AM • Reptile • Answered on Mar 24, 2018
Best solution to keep snakes away from home?
The first step in keeping snakes away from your house is to control the factors that are attracting them there in the first place. It is time to roll up your sleeves and do some work in your yard. Remove weeds, excess vegetation, piles of debris and any other areas where snakes can hide. http://www.instructables.com/id/How-to-Keep-Snakes-Away-From-Your-House
3/24/2018 11:17:42 AM • Reptile • Answered on Mar 24, 2018
What type of snake is this?
The boa constrictor, also called the red-tailed boa or the common boa, is a species of large, heavy-bodied snake that is frequently kept and bred in captivity. download-fegsgavz0rqgqrigr1jhdrvj-1-0.jpeg Boa constrictor
3/24/2018 11:14:53 AM • Reptile • Answered on Mar 24, 2018
Water standing in drain.
You can start with a half cup of baking soda and pour that down the bathtub's drain. ... After 30minutes has passed, pour the hot water down the drain.
3/24/2018 11:12:22 AM • Reptile • Answered on Mar 24, 2018
Common snakes in Mississppi
There are 55 different kinds of snakes in Mississippi and only six are venomous, according to the post. The six venomous snakes are Eastern Diamondback Rattlesnake, Copperhead, Canebrake Rattlesnake, Pigmy Rattlesnake, Cottonmouth and Coral Snake.
3/24/2018 11:10:58 AM • Reptile • Answered on Mar 24, 2018
What is the most common snake in America?
Garter Snake
11/3/2017 12:54:03 AM • Reptile • Answered on Nov 03, 2017
I need to identify a snake...where can i send you a pic?
You can do a Google Picture search. Or, do a search of snakes in your state. But remember, DO NOT USE THE WORD POISONOUS! Snakes are either VENOMOUS, or NONVENOMOUS. And you should NEVERRR kill a snake. Even if it is venomous, and you have small children. Most bites occur while trying to kill a snake. And you will NEVER kill all of them, so why kill even one? Don't try to be a hero. There are too many DEAD heros already.
10/26/2017 8:59:24 PM • Reptile • Answered on Oct 26, 2017
Flukers 5.5" Repta Clamp Lamp with Logo
1 questions posted
Top Flukers Reptile Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
john h
Are you a Flukers Reptile Expert? Answer questions, earn points and help others
View Most Popular
Flukers Reptile
  • Flukers Reptile
Most Popular Question
kicks out breaker
  • Reptile
