Press windows button and in the
search type msconfig go to startup tab and uncheck those you dont want to
start.
scroll to the bottom toolbar bottom
of screen right click you can select task manager applications also processes
you will see whats running on your computer and ticking over you might have a
virus
if you see something running that
you does not need to be running select end now then you might you might
uninstall that particular program
and some unnecessary programs
you should also check leads from
motherboard to hard drive for secure dust free connections
click start control panel
administrative tools computer management disk management right click on your
drive select properties click tools you should see click check now
click start tick in both boxes this
will schedule to on restart
do not have any input while chkdsk
utility is in progress any might damage your computer
also you
might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
then defragment your hard drive
adding more ram is the best way of
speeding up a computer
If youre
not sure if a module is right for your system use the
Crucial Memory Advisor tool
for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any
ram and buy working pairs if possible
you might have to many programs
running at the same time
putting to
much strain on the CPU central processing unit
try uninstalling a few unnecessary programs
This tool deletes unnecessary or
temporary files on your hard disk so you can increase the amount of storage
space you have.
Delete the files using Disk Cleanup
If you want to reduce the number of
unnecessary files on your hard disk to free up disk space and help your
computer run faster, use Disk Cleanup.
It removes temporary files, empties
the Recycle Bin, and removes a variety of system files and other items that you
no longer need.
Open Disk Cleanup by
clicking startall programsaccessoriessystem tools
and then clicking Disk
Cleanup.
In the
Disk Cleanup
Options dialog box, choose whether you want to clean up your own files
only or all of the files on the computer.
If you are prompted for an
administrator password or confirmation, type the password or provide
confirmation.
If the
Disk Cleanup
Drive Selection dialog box appears, select the hard disk drive that you
want to clean up, and then click OK.
Click the
Disk Cleanup
tab, and then select the check boxes for the files you want to delete.
When you finish selecting the files
you want to delete, click
OK, and then click Delete files to confirm the operation.
Disk Cleanup proceeds to remove all
unnecessary files from your computer.
This tool deletes unnecessary or temporary files on
your hard disk so you can increase the amount of storage space you have.
no longer need.
Watch the demo (1:00)
and download and install either or
all of these
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system
must be registered
Win7/Vista/XP
64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62
anti malware free edition Win XP/2003/Vista/Windows7
http://superantispyware-free-edition.soft32.com/
You could run the chkdsk disk
utility
Click start run
type cmd then type chkdsk/r/f which will scan for and attempt to
repair any bad sectors and automatically fix any corrupt files on your Hard
Drive.
or an easier way to run the
chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools
computer management ,disk management right click on your drive select
properties click tools click check now click start two boxes
automatically fix files and scan for and attempt
recovery of bad sectors place then a tick in both boxes then select check now,
start should schedule this task when restart
have no input while the chkdsk utility is in progress
any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry,
gets rid of junk files, deletes broken shortcuts, and attempts to give your
computer that like-new feel again.
Optimizers
and Diagnostics.
http://download.cnet.com/360Amigo-System-Speedup-Pro/3000-18512_4-75332741.html
5E3422139C19CBED35C14826A44D4605
Improve your PC performance and fix errors.
Delete some stubborn files
http://www.malwarebytes.org/fileassassin.php
http://advanced-systemcare.soft32.com/ One-Click
Free System tool
this should speed up your computer
