20 Most Recent
Breville BJE510XL Ikon Juice Extractor Questions & Answers
Error message
I fixed my juicer that had this problem, the problem was the thermal fuse which is located directly on the motor with some plastic covering it. You can replace the fuse or do what I did and just cut off the fuse and attach the two wires together (no more fuse) and my machine now works again :)
I tried to turn on
there is inside a thermal fuse and it could have blown if wet, can be replace it is 1/8 x 1/2 " long .inside the machine turns off everything when blown , and purchased @ Radio Shack for about $ 5-8 dlrs rated @ 8-10 amps , need more info , if this works for you >
Motor burn out
to clarify- I was just starting out this morning, juicing some carrots and heard a pop (carrot chunk hitting the inside of the pulp cover) and the machine stalled.
Hi. I need an instruction manual for Breville JE24 Juicer.
Hi ShirleyI do not see the JE24 listed any where on the Breville Support website.Therefore, I suggest that you use their toll-free number (or email them) to aid you in finding your manual:http://brevilleusasupport.com/talk-to-us/Call them @ (866) 273-8455, Mon.-Fri. 8-5 Pacific time.Good luck!
