20 Most Recent Bosch 11316evs Elec Vs Sdsmax Demolition Hammer Questions & Answers
It doesn't star. Power cable is good What another
The electric field contacts carbon brush autostop in it is activated or is stuck on dirt .
2/26/2016 10:27:59 AM • Bosch 11316evs... • Answered on Feb 26, 2016
Will not come on the unit has only been used for
In this cases allways your warranty the contacts of the electric field were very vulnerable of this model and sometimes the carbon brushes are only stranded on dirt.
2/26/2016 9:45:22 AM • Bosch 11316evs... • Answered on Feb 26, 2016
Which parts need to be greased before I put it back together
Bosch 11316evs a hammer where are complete maintenancekits for with the right grease beware of the parts that are have high priority to observe ALLWAYS REPLACE POS 41 and 39 together to get the neccesary pneumatic vaccuum for the mechanism because if there is leakage of oilseals the o-rings are to early getting HOT and harden prematurely again. also Also note that the statorfield is mounted with two screws, because it does happen often that these 2 screws are not used!! and this in order to prevent the mangle with the four sliding contacts A nice old model hammer GBH 11 in the Netherlands and or the same as this new product http://dasen-hammer.en.made-in-china.com/product/BMgJKvoEXFpm/China-High-Quality-11e-1500W-Electrical-Demolition-Hammer.html but finally this is what you are looking for your hammer .!!! POS 898 partnumber 1.617.000.190 a consumables kit http://www.powertools-aftersalesservice.com/public/boschprof/service?p_auth=aR4sBRMv&p_p_auth=WUDGLa1r&p_p_id=WSRP_bc93764e__6873__4b00__9a29__b331c9759da9&p_p_lifecycle=1&p_p_state=normal&p_p_mode=view&_WSRP_bc93764e__6873__4b00__9a29__b331c9759da9_wsrp-navigationalState=L0JPUy9QVEFTLVBULVNJUy1TaXRlL25sX05MLy0vRVVSL1ZpZXdQcm9kdWN0LURpc3BhdGNoO3BnaWQ9YmI5NWI3MGRjM2E3NzQxY2ExYzA0OGYyM2IzMF9fNDlzR3JsO3NpZD1QMzhKeVRtclkxWndER19mQlhFVk1qWWdLYlM2S19Dd3BYNktZcnNMOW1TVHlMb0F2ZDg9
12/18/2015 5:15:50 PM • Bosch 11316evs... • Answered on Dec 18, 2015
Drill bit doesn't spin yet when turned on hammer works
you dont use drill bits in demolition hammers!!!!
6/30/2015 4:54:10 AM • Bosch 11316evs... • Answered on Jun 30, 2015
Bosch demolition hammer bearings are ceased up, how can I remove it properly to replace?
Ok here goes. Purchase or use the bearing cover nut 3613461500 that you have taken from the base of the machine. and drill a 6mm hole in it. remove the armature from the machine and measure how far the end of the armature sticks out of the bearing. then fit the cover nut onto the bearing holder and whilst supporting the cover nut use a puller or press to press the armature off the bearing through the cover nut. Replace the bearing in the holder and press the bearing and holder back onto the armature until the amount of armature shaft showing is to the same distance that measured in the first place. Hope this helps.
12/17/2012 8:36:25 AM • Bosch 11316evs... • Answered on Dec 17, 2012
Bosch 11316EVS doesn't star. Power cable is
most common problems with these units is brush replacement, or even the on/off switch, I work for a home depot tool rental and are constantly replacing the brushes.
12/15/2012 3:11:33 PM • Bosch 11316evs... • Answered on Dec 15, 2012
Comes on will not jack hammer
If your motor is working but you aren't getting the hammer action you likely have a broken connecting rod (PN 1612001033). Everything in the impact mechanism housing is made of hardened steel except the con-rod, it's plastic and notorious for breaking. If you go into the mechanism to verify the part is broken keep track of where and how everything goes together, there are a lot of parts in there. If you go to http://www.ereplacementparts.com/ and search for your model number you will get a good breakdown of your demo hammer, the con-rod is item #70. You can order parts from them or use the part number to search the web.
2/15/2012 5:59:12 PM • Bosch 11316evs... • Answered on Feb 15, 2012
Bosch 11316EVS demolition Hammer soft start not
Variable speed control module has failed, however you can still use the tool. Hammering action will improve with a good cleaning of internal parts and apply new grease. Hammering action is caused by air/vacuum cushion between drive piston and driven piston which inturn hits a third piston that actually impacts the bit. If third piston is worn, chipped and lodged with debris, there will be light hammering action. After use, store the hammer with the nose pointing down so that the driven piston will slide to end of cylinder and ready for next use.
9/27/2011 3:23:26 AM • Bosch 11316evs... • Answered on Sep 27, 2011
2answers
Need owners manual Bosch 11305 Demolition Hammer
notify bosch or dealer
12/2/2021 6:04:59 PM • Bosch Hammering • Answered on Dec 02, 2021
Bosch Demolition Hammer Drill 11241evs striker c-ring removal picture or video?
https://www.youtube.com/watch?v=JMGwvpDpu9w
5/11/2020 5:50:59 PM • Bosch Hammering • Answered on May 11, 2020
How do i trobule shoot my bosch hammer drill, does not turn on
get a multi-meter and test switch and wiring
10/16/2019 12:55:05 AM • Bosch Hammering • Answered on Oct 16, 2019
Where do i put in oil on bosch 11305 demo hammer
Beware for all not all parts are more available, there is no oil used only Grease Service Pack 1617000036 for Bosch Power Tool eReplacement Parts
8/12/2018 10:31:19 AM • Bosch Hammering • Answered on Aug 12, 2018
Bosch 11316evs Elec Vs Sdsmax Demolition Hammer Logo
13 questions posted
Top Bosch Hammering Experts
john h
ADMIN Andrew
ADMIN Andrew
jabbar huusain
jabbar huusain
Level 1 Expert
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
View Most Popular
Bosch Hammering
  • Bosch Hammering
Most Popular Question
put armature back bosch 11316evs
  • Hammering
