20 Most Recent
Proscan PLDED3273A 32" LED 720p HDTV with 60Hz Refresh Rate & 3 HDMI Questions & Answers
Why do i have very little sound on dvd setting?
Hi ,
Please first check your dvd player to see if there isn't a sound volume control for the output .
Otherwise , check the HDMI connections .
You can also verify if a volume control exists for the sound input of your TV set . If necessary , compulse user's manuals of both units .
Best regads .
9/4/2014 4:53:05 PM •
Proscan...
Answered
on Sep 04, 2014
The tv keeps saying run auto channel scan
I have run the auto scan many times and it never finds any channel. I found that you have to put it on the HDTV, PC, AUDIO channels in order to watch or connect anything on the TV. Try doing that.
11/22/2013 3:31:16 PM •
Proscan...
Answered
on Nov 22, 2013
Unable to adjust the tint
I think your TV may not have this option at all. However, I can also come up with other ideas:
Some adjustments might become unavailable depending on the input or content, have you tried adjusting this parameter in different inputs? e.g. TV channels, HDMI, composite, component? Or different content? e.g. HDMI input but with a signal from a bluray player playing a bluray disc vs. signal from a bluray player playing a DVD. If you don't see the tint "unlocked" in any of these different scenarios the option might as well be natively unavailable.
11/21/2013 11:40:39 PM •
Proscan...
Answered
on Nov 21, 2013
Cant opendownloadedfiles onproscanplt8816k tablet
The files maybe in a ZIP file and if so you will need to unzip the file before you can work with it. The software you got with the scanner should have the files on it to unzip the files after downloading them, just double click the file and follow the instructions. Hope this helps.
5/8/2015 4:42:34 AM •
Proscan...
Answered
on May 08, 2015
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
