20 Most Recent
Stanley Bostitch Rn461 Gun Coil Roofing Nailer Questions & Answers
The Best Benefits of Metal Roof Coatings By Conklin
When our white roof coatings are applied to commercial metal roofs you will save money since the frequent local roof repairs will be virtually eliminated. When roof damage occurs from wind and hail storms occur elastomeric white roof coatings are the default choice. In reality Conklin Roofing Systems should be your default choice since they manufacture the best products in the market.
http://roofinghorizon.com/conklin-elastomeric-roof-coatings-austin.html
New nailer double firing and jaming
Some trigger valves (tva6) are sensitive (defective?) however there are some things you can try to change how the gun acts. I have noticed that the brand of oil has an effect on the orings. Some brands will swell the orings, I like Paslode nail gun oil. Do not wash the gun with gasoline or wd40. Use diesel. Change the nail depth setting one position. Lowering the air pressure will make a difference. I find that most operators use too much pressure. A stronger safety spring under the trigger will separate the trigger and firing pin quicker. Finally you could use single fire trigger. Good luck
Air leaks through cap vent
I had the exact same problem after doing a complete rebuild. If you are using the Stanley bostitch rebuild kit, check to see if you accidently swapped o-rings 6 and 63. They look the same but o-ring #6 is 1.925x.103 and o-ring #63 is 1.862x.103. Use plenty of lubricant. Hope this helps.
How can I stop a RN46-1 from jamming
We often see jamming with stainless wire collation - the problem is almost never the gun, it is because the stainless wire is much harder to shear off than regular steel. I would suggest trying another brand of nail and see if that helps.
Also, yes, the trigger is all that is required to change it to sequential, it is a very easy swap.
How to remove a broken nail head from the driver pin
It depends on how it is jammed - most of the time you need a long drive punch the diameter of the driver and carefully hammer the driver past it. The roofing nailers aren't as hard to free as the framing guns so you should not have any trouble.
Driver not retracting
need to rebuild, or check the head ( grease orings with lithium grease sometimes dry)
Trigger is leaking air and trigger is not working
replace trigger valve assembly aka tva 6 you can get aftermarket ones fairly cheap that are just as good. it is fairly easy to do, usually takes about 10-15 min, lots of how to on you tube look under bostitch rn46 trigger
How to get the retaining ring off of the feeder assembly
The rn46 nailer has two retaining rings for the feeder. The snap ring on the very back of the feeder assembly is removed with snap ring pliers or two small pointed tools of your choice. The rear cap will come off with spring pressure so be ready to catch the pieces. You need to remove the nail canister to see the rear snap ring. The feeder pin holding the feeder onto the feeder shaft is just a rubber ring that can be removed by prying behind with flat blade screwdriver. Caution when you remove the feed-pin and move the feeder or you will lose the feed-sping under the feeder , Good luck
My brand new bostich roofing gun froze up after
Water in gun or wrong oil for cold temp will cause gun to freeze. Make sure that the compressor is not making water form in hoses due to hot air entering cold hose then freezing in gun. Remove cap of nailer and check for water and lube with light oil that remains liquid in your temp range. If the oil is too thick, the firing valve under trigger and headvalve will not budge. Use very short hose so warm air in tank can reach the nailer (heat is produced when air is compressed, however long hose will allow air to cool before entering gun). Stay warm and good holidays
New nailer has low air pressure
Assuming that you mean low power becauss pressure is adjusted at the compressor and should be set to between 90 to 100psi. Pressure at the gun should not drop below say 80 psi. Low power is generally caused by worn piston oring. Easy test, open side door and remove the nails. If the driver drops to bottom and moves when you tilt the nose of the gun up, piston oring is worn. Replace with part # 850607 or universal oring number #222 available at bearing retailer. Good luck with your nailing projects.
