20 Most Recent
Yamaha RX-V995 Receiver Questions & Answers
Yamaha RX-V995: Remove On Screen Text
Here is a dumb try :). Connect your video source directly to the TV/projector, bypassing the receiver from inserting any messages.
If you are probably going to HD sometime, you would need to do that eventually as 995 doesn't have HDMI/Digital Video switching.
Hi i have a yamaha rx-v995 reciver and just
1) Check to see if the screen says "EXT DECODER". If it does, press the EXT DECODER button again and this should fix the problem
2) Press input mode button until the display reads auto or digital. It may be set to analog.
Is it a good idea to upgrade capacitors in power supply,nd othe routput areas
You can replace with elna rubycon FRAKO or F&T caps a good size , but aware that you will have the capacity exactly the same and the voltage a 10 volt higher because of new capacitors of the same value can have a smaller size with the same voltage and capacity and the little size format can be giving a not nice sound but also all replacement capacitors in the beginning have a 2 days neccesary Black-gate or some ELNA caps much longer before it will sounds good , if you have had leaking caps like the brand of ITT if used especially the big blue ones, or nichicons clean the print outdoors with a nose pliers use on a canister gaslighter gas and spray on the free positions on the print where the leaking capacitors where placed and also to clean the whole print . it removes conductive materials and also if you have ones in your life have wallpapered indoors and have prepared wallpaper paste and this amp was in the same room you have luck by this tip because methyl cellulose can be highly conductive eventually creep and especially static seen very high electric malfunctions if you get your fingers on places without cleaning also after years !!! , and now you have your amplifier open and wish to customize it its your chance to prevent hidden faults, especially if you want to brush up on vintage equipment with analogue techniques. Yamaha vintage capacitors if you have a capacitance meter you will see if you have a capacitor that looks good in most times if you measure it you have sometimes a remarkable value because the capacitors have a strange tolerance that will not deformed down but to high 100 mf can be have an capacitance of 230 mf too great tolerance that is not a problem if all the capacitors are not replaced , but if you have checked this you will know you must replace ALL the capacitors at the same time (not the very little ones ) but measure is important or there are components that will be burning out , strange and remarkable but it could happens. good luck .
How do you connect a Nakamichi surround sound system to my Phillips tv model 42PF7220A/37
I'm confused. The message header shows a problem with a Yamaha RX-V995 receiver.
As for connecting a Nakamichi (or any surround system) to a TV - the only connection would be the Monitor output (video connection) to an appropriate video input of your TV.
If it is a Nakamichi, it is a little older and probly predates the invention of HDMI cables. My guess is you will either use the S video output or Composite video output to the TV's input with similar connections.
This allows you to route whatever video sources you have connected to the Nakamichi to the TV.
