20 Most Recent Yamaha RX-V2500 Receiver Questions & Answers
All digital inputs dead
Main control board fault. Contact the authorized service center. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
7/11/2015 3:52:53 AM • Yamaha RX-V2500... • Answered on Jul 11, 2015
If only setting up for 5.1 what speakers would be
For 5.1 you would use just Surround the Back surround would give you 7.1
3/6/2011 10:39:16 PM • Yamaha RX-V2500... • Answered on Mar 06, 2011
Can you tell me please: where do you insert cables
the coaxial cable from outside is connected to in (box), coaxial cable from out to digital in (RX) digital out to TV... (try scrolling through source to cable/ or component if this is HD) (all other devices can be connect to RX also like dvd using Red Yellow White cable or S-video w/red & white)
8/25/2010 1:31:46 AM • Yamaha RX-V2500... • Answered on Aug 25, 2010
Where do I plug rca cables from the cable box into
Depending on what type of connections your cable box has available you can do the following:
1) If yo only have the standard VIDEO & L R AUDIO connections you can use the DTV connection on the back of the V2500. If your cable box also has an S-VHS connection this would be the same connection to use.
2) If you have COMPONENT VIDEO connections on your cable box then you would still use the DTV connection. Looking at the back of your V2500 the regular DTV RCA connections are just to the left of center. Farther over to the left are the COMPONENT VIDEO connections. They are labeled Y, Pb, and Pr. These allow for the higher needs of HD TV transmissions. If your cable box has these connections then making use of them would allow for the best quality for your picture.
The following website has your manual available for download in case you need it:
http://www.devicemanuals.com/guide/Audio%20and%20Video/Yamaha/Yamaha-RX-V2500-Owner%27s-Manual-TVRBek9UVT.html
Please let us know if you need any further assistance with your issue.
3/12/2010 7:54:31 PM • Yamaha RX-V2500... • Answered on Mar 12, 2010
Just stopped working.Doesn't power up you can
This isn't something we can help you with. Keep a fire extinguisher handy if you want to keep messing around with it. It needs hands- and eyes-on by a pro.
2/3/2010 11:38:34 AM • Yamaha RX-V2500... • Answered on Feb 03, 2010
0answers
3answers
Onkyo HT-R520 Immediatly goes
This Yamaha model has a "Thermal Protection Integrated Circuit", You can check the online manual at www.yamaha-uk/pdf/owner_manuals/rx-v2500.pdf
5/23/2009 8:13:58 PM • Yamaha RX-V2500... • Answered on May 23, 2009
2answers
Yamaha RX-V800 - No audio on left and right channels
I too am experiencing this problem.... and my receiver is only 5 months old. Its a RX-V661
2/27/2009 5:13:20 AM • Yamaha RX-V2500... • Answered on Feb 27, 2009
Zone 2 connections
go into your amp settings menu then to speaker settings,set zone 2 on and main on, turn up the volume for zone 2 about half way then connect phono cables from zone 2 pre out to a input on the external amp (eg cd input )
never use the phono input this is for turntables,connect this amp to your speaker switch/selector then to speakers.
hope this helps
cable guy.
6/4/2008 9:37:11 PM • Yamaha RX-V2500... • Answered on Jun 04, 2008
No Sound
check the audio circuit the set might have some lose solder.if that does not work replace the audio output.and related circuit that will remedy your problem,good luck.
3/23/2008 11:53:05 AM • Yamaha RX-V2500... • Answered on Mar 23, 2008
Why does my Yamaha HTR-6130 power down after 3 seconds?
I expect there is either a power supply issue or one of the amplifiers has failed causing over current to turn it off as a protection to the power supply.
4/20/2024 6:23:32 AM • Yamaha Audio... • Answered on Apr 20, 2024
Yamaha RX-V2500 Receiver Logo
26 questions posted
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Audio Players & Recorders
Most Popular Question
plug rca cables from cable box into
  • Audio Players & Recorders
