20 Most Recent
Viper SmartStart Module Questions & Answers
Viper rpn 7752v battery
error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly, complete refurbish, repair, installation every single thing is covered
within seconds u can get the access and it's totally illustrative complete
I've had a SmartStart installed on my truck for
is your service plan still active? check mysmartstart.com to make sure it does not need to be renewed. otherwise try calling their technical support line mon-fri. this error message is typically associated with an account issue.
When i unluck doors the car doesn't make sounds
You should check the manual of your alarm system. there is some settings for silence. lets say if u press to buttons on your remote and hold it for a little wile it might get the sound but if its factory alarm system than might its originaly without sound. but no worries any way if any one will try to brak into your car it will start to scream
Dsm200 drains battery
The DSM is supposed to be on all the time. The current draw should be no more 15 Ma. Is there a question here?
I cant start car with my phone
Smart Start not working?! Was the unit tested for signal strength and proper operation after installation? If so, and the unit works, did you receive confirmation from Directed Electronics with a link to set up your account? Did you activate your account with Directed Electronics? After activating, did you download the app through your phone? If you have done all of the above and the Smart Start still does not work, your next contact should be made with Directed Electronics and the installer. **Please Note** Downloading the app without activating unit does nothing. Installing the unit without following the setup and test procedure does nothing.
Car remote starts by itself
if this is happening during cold weather than its perfectly normal it dose it to keep the coolant in the moter from freezing. you should be able to look in the manual and see how to turn that feture off.
Hi, I just upgraded my
Are you able to login to your account?
Have you selected your vehicle?
What specifically is not working?
How to fix My Directed Electronics Smartstart? I
Is the installed remote car starter one of these models:
- Clifford: models 1.2, 1.3x, 20.7x, 2.2, 3.3x, 50.7x, 590.2x
- Python: models 1401, 580, 1601, 872, 991, 592
- By transmitter type: 1-way SuperCode (RS or Sec/RS), Responder LE (RS or Sec/RS), Responder LC3 (RS or Sec/RS), Responder HD
I downloaded and checked the user and installation guide and neither say anything about what the codes are. I guess they want to charge you to tell you what is wrong. It is possible the code is being thrown by the remote starter itself but without the model number I can't tell you what the code means. If you still have the user guide for the remote starter or can download it, it should tell you what the code is.
I had my Smartstart intalled
The multiple flashes of the parking lights are shutdown diagnostics:
1. 1 flash is runtime expired
2. 2 flashes is over-rev shutdown
3. 3 flashes is low or no rpm (tach wire)
4. 4 flashes is transmitter shutdown
5. 5 flashes is + brake shutdown
6 6 flashes is - hood shutdown
7. 7 flashes is timer mode/turbo mode manual mode error
8. 8 flashes is neutral safety shutdown ( the remote start control switch is in the off position).
9. 9 flashes is low battery (voltage setting)
10. 10 flashes is alarm triggered
11. 11 flashes is wait-to-start input timed out.
Hopefully, the above mentioned diagnostics will help you determine why your remote starter is not working and you will begin to enjoy the system.
