20 Most Recent
4103LX 4Button Remote Start System with Keyless Entry Questions & Answers
Hey got a question
Technically you can. Practically speaking though it would take some real skill in electronics. Basically, the lock/unlock outputs are just negative pulses. You would have to pull a circuit schematic and:
a) determine the polarity if your wipers
b) identify the correct wires
c) create a latching relay
d) connect everything electrically.
If the wiper switch rests at ground, you will have to add a relay
Avital whining noise from control module
I have installed countless avital systems and have NEVER heard of a whining noise coming from the module. Based on your other comments as well, I would HIGHLY recommend that you visit a qualified install shop to check your work before real damage is done.
It has quit working. The fob/remote has a good
yes, there are two fuses on the main wiring harnesses for the remote start brain. also try reprogramming the transmitters:
1. Turn key to ignition position (ON)
2. press and release programming button (you will need to locate this in your vehicle, ask your installer where this was placed; it can normally be found under the driver's side of the under-dash)
3. press and hold programming button
4. while holding programming button, press lock on each transmitter one at a time.
5. Turn key off and remove, test transmitters.
How can put my Avital 7345L remote starter on vibrate instead of chirping?
To put your Avital 7345L remote starter on vibrate instead of chirping, you will need to follow these steps:
- Press and hold the "Valet" button on the remote starter until the parking lights flash twice. This will put the remote starter into valet mode.
- Press and hold the "Lock" button on the remote starter until the parking lights flash twice. This will turn off the chirping feature.
- Press and hold the "Unlock" button on the remote starter until the parking lights flash twice. This will turn on the vibrate feature.
- Press and hold the "Valet" button on the remote starter until the parking lights flash twice. This will exit valet mode and save your settings.
- Test the remote starter to make sure that it is vibrating instead of chirping.
Note: If you have difficulty following these steps or if you have any other issues with your Avital 7345L remote starter, it is recommended that you consult the user manual or contact the manufacturer for assistance.
How can I get instrction book for reprograming avital remote starter for rpn 7111l
If you are looking to sync the remote key fob to the remote starter:
Remote programming 1. Turn key to the ON position 2. Within 5 seconds, press and release Valet button one time. 3. Within 5 seconds, press and hold the Valet button. The LED will flash one time and the horn honks to confirm entry into remote programming. 4. Press the button on the remote control. 5. The horn honks to confirm the remote has been programmed. 6. Release the Valet button, and turn the key to the Off position. 7. The horn sounds one long honk to confirm that remote programming has been exited. The programming routine exits if any of the following occurs: • The ignition is turned off • There is no activity for 30 seconds • The Valet button is pressed too many times
