20 Most Recent
5101 LE 1 Way Car Remote Starter System Questions & Answers
Remote starter doesn't work when pressed
I think that you answered it yourself. Give you 1 point. The continual is the processor searching but not finding its mate. Replace the battery and repair them.
My remote starter will start the car, but the heat will not come on until the key is in.
Did the heater work before? When these units are installed, there are specific relays (optional) that can be installed for various high-current devices such as the HVAC, window defoggers, etc. They require additional parts and labor to install, and may not have been (although it seems unlikely for the heater). Otherwise, there may be a relay malfunction.
How do I reprogram a viper 5101 remote starer
on remote press the middle button for 15 sec. after three flashes on remote, put key in ignition and turn ignition on but dont start it. press button on antenna, release and then hold until horn honks or led flashes on antenna. lastly press lock within 5 sec
How to program 473v remote
Open the door, turn the key on, press valet switch one time and press it again and hold it until alarm beeps if it dosent beep it means that alarm hasn't read the door open if it beeps press lock on the remote and it should beep again and its will be set. (if the alarm dosent beep you have to put the door trigger wire (green) to ground and repeat steps from beggining
Only use these remotes to lock my car. Alarm keeps
hialarms normally activate when they are trigged do you have a bonnet door or boot switches connected to the alarm systemyou have to eliminate each switch open one door at a time and hold down the switchlock the car with the remote if it gos off its not that doormove on to the next door and repeat the process if it does the same thing with all the doors there working properly go to the boot or trunk and hold down the switch if it gos off thats good go to the bonnet or hood and hold down the switch if it gos off you thats good have eliminated all switches if at any time any one of them dosent go off you have found the problem try that firstaries
I changed the battery in my remote now my car will not respond
Reprogram the remote: press and hold the f button for approximately 8 seconds. the remote will flash three times. press the remote start button on the remote. the remote is now ready to pair. enter vehicle, turn ignition on, press and release button and antenna, immediately press and hold same button, the vehicle should respond with a horn honk and/ or light flash on antenna. While holding button on antenna, pres lock button on remote...vehicle should respond with a confirmation horn honk and/or light flash. Release button on antenna, turn vehicle off. Test system.
Out of nowhere, the doors
The system is in valet. Press the "F" button twice then, press unlock. This will take the system out valet. This will handle the blue light/horn honk. As for the door locks, that may very well be another issue.
Remotes won't program! Installed Viper
There are two constant 12 volt wires at the ignition on this vehicle: blue and green. The red power (with fuses) wires from the Viper should be connected to either of the two. The ignition wire is yellow. The pink wire from the Viper should be connected there. The accessories are orange and white. The pink with white from the Viper should connected to one and the orange from the Viper should be connected to the other. Please note that the Pink with white should be programmed to act as an accessory (off during crank). The starter wire is red and the purple from the Viper should be connected there. Also check for a good ground connection.
For programming:
Press and hold "f" until LED lights solid (approximately 10 seconds), then press and hold remote starter button(circle w/arrow) until LED blinks three times and the amber transmit LED lights up.
Now you have to enter the remote control learn routine: Turn ignition on, within ten seconds press and release control button on antenna then, press and hold control button while pressing the lock button on remote. System will respond (horn/chirp/flashing parking lights) when holding control button and when pressing lock button on remote.
