20 Most Recent
350 HV ESP Security System 350HV ESP Questions & Answers
Valet mode
The valet button location is decided by the installer and is usually hidden. Find the main control unit and follow the 2 wires to the valet switch.
I have a 350hv viper
I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 years
Car alarm doesn't go off with light impact
that alarm has an impact sensor which will detect sharp impacts to your vehicle. No shaking will set off the alarm unless you buy the digital level sensor also available from directed electronics , the makers of Viper car alarm,
please also note you must wait 20 seconds after arming the alarm to test any sensors. If you arm the alarm and immediately open a door or test a sensor ,that door or sensor will be considered a defective zone and will be bypassed and will not setoff the alarm tell you reset the alarm by turning the ignition key on and off.
System will not come out of valet mode
now ill probably be talking weird and you wont follow but try to with every vipor system theres a black switch under dash or down by the back consul in front seat areaonce you find the black button press and hold for 7 seconds this should release the valet parking and put back into normal modeim not sure if it still does with key on the on position or the car can be offgive me shout the button is lovely to find in vehicles for vipers lol
I am installing a DNA keyless entry system on my
After installing the kit just put a bulb on the desired wire and ground.It will show you the signal (if it has one).Smaller bulb better,because it will show you even short signals.Multimeter is better for this if availabile.
My viper alarm system when armed and disarmed there is no sound from the speaker
Either the system is in valet or, the chirps have been deleted or, the siren is broken.If the LED is on solid the system is in valet. open the door, press lock, unlock, lock on the remote to remove valet.Press and hold the lock button. This activates the car finder/panic. The siren should begin to wail. If it does, the siren works. If it doesn't and all you see is the aprking lights flashing the siren is defective.
I need to program a fob or remote system not
If your short a key fob or lost yours this is a cheap way to replace it.
I purchased my fob on ebay for $30 and programmed it myself.
**Read all the way through. The last line is important.**
1. Make sure all doors, hood and trunk are closed.
2. Open the trunk door.
3. Open the drivers door and sit in the drivers seat.
4. Close the drivers door.
5. Turn ignition switch to on and off 5 times ending in off.(do not start the car turn to just before starting)
Your alarm light will turn on and the siren on the alarm will chirp to let you know it is ready.
(this can also be used to test if you have the alarm)
6. Open the drivers door stay in the seat close the drivers door.
7. Press any button on the remote. The light will flash to indicate your remote has been programmed.
8. Repeat steps 6 & 7 to program any other remotes, up to 4 remotes a car.
9. To exit program mode open drivers door leave the door open. Close the trunk lid and close the drivers door the
siren should chirp again and the red light will shut off. Test your remotes to make sure they work right.
******Note all the steps from 2 - 5 must be done within 45 seconds. Step 5 must be done within 10 seconds.
I reeplaced the fuel pump,
You must put the alarm on a valet mode to see if the alarm is causing this problem
To enter or exit Valet Mode
1. Turn the ignition on
2. Turn the ignition off
3. Press and release the valet switch within 10 seconds
The status Led will light solidly if you are entering valet mode, and it will go out if you are exiting valet mode.
To enter or exit Valet Mode using the transmitter:
1. Open any vehicle door.
2. Press and realese lock and unlock buttons at the same time
3. Press and realese Aux button
4. Press and realese the lock and unlock button at the same time again
The status led will light solidly if you are entering Valet Mode and it will go out if you are exiting Valet Mode
Now when in Valet Mode try to start the engine, if the problem persist the alarm has nothing to do with it
Hi trying to find wiring
Fig. : Optional anti-theft system and remote keyless entry system wiring diagram - all models (click over pic for zoom)
Also, could find additional diagrams in
THIS LINK.
Hope this helps; keep us updated.
12/29/2010 11:40:12 PM •
350 HV ESP...
Answered
on Dec 29, 2010
My vw beetle 2004 wont
HI,
Check your alternator wiring connections first.
This may occur due to three reasons
1)Loose battery cables.
2)Defective battery.
3)Bea cause of Fuses.
3)Alternator.
*)Take the battery to have it tested.Check the voltage with your volt or multi-meter, it should read around 12.5v. If there's an Auto zone there, they do free testing If you gradually lose battery power, it's the alternator. If there is no power at all, check your fuses.
*)Look over all of your fuses, to make sure none of them such as the fuel pump fuse, or the fusable link have burned out
*)Check your alternator wiring connections first.
*)Likewise if your vehicle is equipped with a MAP (manifold absolute pressure sensor) be sure that is plugged in correctly.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
My 350hv just shuts off randomly. I can arm it and
Sorry, but it is my opinion that car alarms are really, really foolish.
Cars are extremely hostile environments for delicate electronics.
Adding alarms is begging for problems that will leave you without a car.
If you lock any valuables in the trunk, out of sight, there is no reason for an alarm. All an alarm will do is either fail and prevent you from driving, or fail and get you a ticket for a false alarm.
