20 Most Recent
Proform XP 580 Trainer Treadmill Questions & Answers
Keypad doesn work
the red light should only blink when it is running. does the incline work? if nothing works most likely a console issue
How do i oil my treadmill and with what
Always check the owner's manual before choosing lubricants for any treadmill. Treadmills could be designed to use either wax-based or silicone-based belt lube. Low maintenance treadmills could even be damaged by unnecessary lubrication. Watch the following video to know how to iol your treadmill.
ok
Pro-Form Crosstrainer XP 580 Board Failure?
Their is a sensor within the incline motor casing that may not be functioning
thus causing the motor to repeat the cycle. You will most likely need to replace
the incline motor.
Fluctuating speed
With the motor being new and the "hot electrical" smell, I would say the motor control board, which sends the speed command to the motor, would most likely be your issue.
