20 Most Recent
Toshiba e-Studio 350 Copier Questions & Answers
Firmware for e-studio 282
I need firmware becuas the machine in errer f 103 i chage the HDD
than HDD need the softwer Pleas Give me a free softwe side
How can i fix the
1. Check and clean the main charger, replace if required.2. Check and clean the transfer/sep. unit, replace if required. 3. Before you replace the HVT board, check HVT connector bracket (the black color plastic piece mounted on the machine frame where the main charger connects). If this part is damaged or cracked, the high voltage will arc through this, which can cause C970. (found in several machines).
Toshiba estudio 455 firmware update failed
Hi guys please have suffer a lot to download estudio 455 firmware but no avail please can anyone help me with the correct site to download the latest firmware may the Lord God bless anyone that will be of help
Error code F105 studio 450
F105 indicates HDD other error
Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If the check result is failed, replace the HDD.
Close Front Cover For Toshiba E-studio 350
There are many possibles that can cause "Close Front Cover"
Check the front cover actuator, switch. If all covers, switches is working fine, probably power supply is faulty.
Error code on toshiba e studio 350 code is f110
Communication error between System-CPU and
Scanner-CPU
Check if the harness connecting the SYS board and SLG board is disconnected or open circuited.
Replace the SYS board. Replace the SLG board.
Bypass feed
this is set by the computers driver
or its detecting no paper in the main drawers
HOW TO RESET NETWORK INITIALIZING LIGHT TOSHIBA
Press User Functions>Admin>then enter 123456 (password) then go to the TCP/IP section and clear all the IP addresse/s out of the fields then hit enter.
Press Back>Back>Copy>User Functions>Shutdown. then turn the machine back on.
TOSHIBA E STUDIO 280 CALL FOR SERVICE
First of all check what is sub code with this .if it is not showing code press clear & 8 key at same time .code will bi shown .if no code just reset pm cycle count.MIAN AKHLAQ
