20 Most Recent
Eforcity FM Transmitter Car Charger compatible with SamsungGalaxy S 4G Questions & Answers
Delete international clock from galaxy 4
About 1,620,000 results (0.50 seconds)
Search Results
www.itjungles.com/samsung-galaxy-s4-how-to-create-and-delete-clocks-...
Due to business trips and different time zones/ working hours, you may sometimes need to use World clock to check your partners time zones to send emails and ...
forums.androidcentral.com > ... > Verizon Galaxy Note 2
Jun 28, 2013 - Recently, when making a call, the world clock appears and requires a bunch of clicks to close. ..... I have a Samsung Galaxy S4 with Verizon.
LG G3 - world clock widget that will show two time zones ...
Aug 9, 2014
How to remove alarms from the clock?
Dec 6, 2013
Samsung Galaxy S4 Android 4.3 Update Issues - Page 3
Oct 28, 2013
How to remove clock and weather off lock screen?
Oct 26, 2013
More results from forums.androidcentral.com
Tune dab radio sa pm250?
To tune a DAB (Digital Audio Broadcasting) radio such as the SA-PM250, you can follow these steps:
Power on the radio: Ensure that the radio is plugged into a power source and turned on. Look for a power button or switch and press it to activate the radio.
Select the DAB mode: Most radios have different mode options, including AM, FM, and DAB. Locate the mode selection button or switch and choose the DAB mode. It may be labeled as "DAB," "Digital," or have a DAB icon.
Initiate an initial scan: When you first set up a DAB radio or if you haven't used it in a while, it's recommended to perform an initial scan to search for available DAB stations in your area. Look for a "Scan" or "Auto-tune" button and press it. The radio will scan the frequency range and save the available DAB stations it finds.
Navigate through the stations: Once the scan is complete, you can navigate through the available DAB stations. The SA-PM250 likely has buttons or knobs to browse through stations. Look for buttons labeled "Up," "Down," or with arrows indicating station navigation. Use these buttons to scroll through the stations.
Select a station: When you find a desired DAB station, stop scrolling and wait for a few seconds. The radio will automatically lock onto the selected station and start playing the audio.
Adjust volume and settings: Use the volume control knob or buttons on the radio to adjust the volume level to your preference. Additionally, the SA-PM250 may have settings for audio enhancements or other features. Consult the user manual for the specific functions and settings available on your radio model.
It's worth noting that the exact steps and buttons may vary depending on the specific model of the SA-PM250 or the manufacturer's design.
How do I change to degree mode on my porpo YH-2000
To change to degree mode on your Porpo YH-2000 calculator, you can follow these detailed steps:
Turn on the calculator: Press the power button to turn on the calculator.
Access the mode menu: Look for a button labeled "Mode" or "MODE" on your calculator. It is typically located near the top or side of the calculator.
Enter the mode menu: Press the "Mode" button to enter the mode menu. This will allow you to change various settings and configurations.
Navigate to the angle mode: Within the mode menu, use the arrow keys or navigation buttons on your calculator to scroll through the available options until you find the angle mode setting. It is usually denoted as "Deg" or "DEG" for degrees.
Select degree mode: Once you have highlighted the angle mode option, press the corresponding button or key to select degree mode. The specific button or key may vary depending on the calculator model, but it is usually labeled with the same abbreviation used for degrees ("Deg" or "DEG").
Exit the mode menu: After selecting degree mode, exit the mode menu by pressing the "Mode" button again or any designated exit button on your calculator. This will save the changes and return you to the main calculator screen.
Verify degree mode: To confirm that you have successfully changed to degree mode, try entering an angle calculation or trigonometric function that involves degrees. The calculator should now interpret and display the results in degrees.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
Audiosonic CR-06PL not changing time when following manual instructions.
Set Time Hours and Minutes: Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press and hold the button for a fast setting or tap it briefly to increase the setting by one hour. Now set the minutes with time (press and hold) and min.
How do I set the Audiosonic clock? Set current time Press and hold the time button and simultaneously press the hour to set the hours in 24-hour mode .
