20 Most Recent
Homelite Mighty Lite Blowervac Questions & Answers
Blower won't start.it's getting a good
Whilst I cannot offer a definite solution to this problem, it is worth disassembling the carburettor looking for dark brown material that collects if you don't drain the fuel tank after each use. I have started running all of my petrol engines dry to avoid this problem of fuel evaporating leaving coagulated oil in the carburettor as a membrane. You won't damage a good motor by doing this since as you should have lubrication for the piston rings right up until the agonal stroke.
How to sdjust carburator "?"
Turn both H and L adj. crews all way in to right counting number of turns on each. Back each one out 1 1/2 turns engine should start adj. H by holding throttle to maximum and adjusting until max rpm then adj.L for idle and very little hesitation when quick throttle. You may the have to tweet each.
How to adjust a home lite mighty lite blower vac carburator "?"
Hi. This link,
http://manuals.homelite.com/documents?page=5
is to the homelite page where the manuals are, however, there are 4 different models of the handheld blower you have. Either way, if this is a really new model, there may be no way to adjust the carburetor, as due to emissions standards, there may not even be any idle screws, but if they do exist, the head ma be whats called "pacman", as it looks like a little....yeah...pacman.
I can't start my blower cold start with out gas
Does it have a primer,to prime about 3-5 times,it may be bad,sucking in air and not supplying gas to carb,replace,they are inexpensive,home depot or lowes should have or look up on line,but you may have to pay shipping.
I do not know the oil-to-gas ratio to mix/buy. My
Can you find the model number on the Homelite Mighty Lite BlowerVac? For the UT08520 and UT08921 26cc blowers and the UT08550 and UT08951 blower vacs, you can mix the Homelite Premium Exact Lubricant with gasoline following the label directions. For other synthetic oil additives, use 2.6 oz of additive per 1 gallon of gasoline. (It's 20ml to 1 l if you use the metric system.) That's a 50:1 ratio (gasoline to additive). Many Homelite Blower manuals are available here:
http://manuals.homelite.com/documents?page=5 . You should try to find your exact model and then check the manual to confirm that your model blower vac uses this same ratio of oil to gasoline. You will need Adobe Reader or a similar program to read the manual.I hope this helps. Cindy Wells
Homelite carb schematics
The fuel pump side goes: carb body, diaghram, gasket, cover.The metering side ( side with the needle) goes: carb body, gasket, diaghram, cover. On the diaghram, the side with the larger disc and the holes around it and the nub in the center goes down toward the needle lever.Any adjustment needles can be set at 1 and 1/2 turns out to start. Turn out to richen. If it falls on its face and bogs when you throttle up then its lean and needs to be richened up.
