20 Most Recent
Echo Blower Nozzle Es 2400 Pb 200 201 2100 21001420561 Questions & Answers
Pull cord won't engage
remove the sparkplug and try to turn the flywheel if it turns freely then the engine is most likely ok. if it does not turn you have a locked engine that means its toast. If it does turn then you have to look closely at th pull recoil that it is engaging the flywheel.
Starts dies
Fuel lines could be collapsing from being soft, mush from ethanol in gas, possibly you have wrong carb kit, or something put together wrong, fuel lines reversed, double check everything then make sure you exhaust screen is not plugged, cause this will do same thing.
