20 Most Recent
Toro Snow Blower Ccr 1000 Belt 715381 715381 71 5381 () Questions & Answers
I have a CCR 3650 Snow Blower
Try the spring on the governor. sounds like it's not hooked up, or extremely week. I rebuild and sell these all winter. I've had it happen a few times. Runs really good! but, will ruin the motor running over speed like that. There are adjustments- some have the spring on a long flange of metal so it can be bent backwards to add tension- it doesn't take much! If the motor starts to rev up and down and up and down, add a hair more tension. It there is too much tension it will stall out when you hit heavy snow.
Toro powerlite 98 cc 16" Mod no 38182 ser
Yes, you have a shear pin and that is probably the problem...
The shear pin often will not fall out and look like a normal piece but in fact be broken...
The shear pin usually is in the main shaft from the transmission to the auger drive...
Some are right on the auger its self...look around you will find it...
heatman101
My snowblower just started back firing,why?
Snow is melting on the engine and causing the spark wiring and/or magneto to short out...
Stop blowing snow and run the engine at a fast idle for awhile to dry off the motor...then it will work again..
heatman101
No pull cord tension
The little fingers on the Starter mechanism may be stuck and not expanding. The Starter mechanism my need to be taken off, cleaned and lubricated
