20 Most Recent
Pride Mobility Products GoGo Elite Traveller 4 Wheel Travel Scooter Questions & Answers
Why does my scooter have very little power
hi , have you checked the charger ? try another charger if possible, how old are the batteries and how long have they been left without charging ?
Regards
Rob
www.gewizrepairs.co.uk
How do I recharge the battery tried replaceing the fuses but it will not charge
the charging fuse on these is internal inside the battery box
1 carry out a continuity test in this blade fuse for open circuit
2 while open check battery volts is over 11 volt or scooter will drive=o/k if lower will need batteries replaced.
3.make sure your charger is the correct one for this scooter
as go go chargers conector are wired different .so a standard mobility charger wont charge these,as there will be no 24volt at pins 1 and 3 ,
The gears are stuck
Try and gently rock your scooter backwards and forwards as you are trying to move the lever this can help. spray a little wd40 on where the lever connects to the motor. If this doesn't help then the electric brake has ceased and needs an engineer to sort.
Electric shocks when sat on scooter and someone
This is probably due to "static" electricity discharging from the rider to earth via the person who touched you. Static is often caused by the clothes you wear (especially man made fabrics like nylon). Try fitting a discharge strip ( like you see on the back of cars) to the scooter or change the type of chothing you wear (wool or cotton does not cause static to build up)
Why does it constantly beep?
hi, it's it's running okay but bleeping , could be low battery voltage or a failure in the bleeping circuit with wiring or the controller...
Regards
Rob
www.gewzirepairs.co.uk
Why does it beep five times when key is turned on and controls won't work
hi, the 5 bleeps are related to the brake,,, located at the rear of the scooter located on the side of the motor, attached to that is the free wheel lever,, in drive mode ,, check that the microswitch is working correctly, check the wire( connectors etc ) from the brake to the controller ,
www.facebook.com/gewizrepairs
What does the 9 beeps mean
hi , That an be caused by a bad connection to the controller , refit sockets on the PG Drives controller.... this can also be a controller fault...
I offer free testing ...you only pay the return postage...
Regards
Rob
hi, the nine beep is a system error (critical error) , , in my experience this can be caused by a bad connection on the controller,
Look at my video showing the long connector, you need to refit that 14 way connector then carefully pushed behind each one where the cable goes into the plug...
You can view the video in any media player or your browser depending on plugins installed.
http://www.rsrc.co.uk/controller.mp4
Regards
Rob
