20 Most Recent Health-O-Meter Health o meter 402KLWH Physician's Beam Scale With Height Rod Wheels Questions & Answers
For the Health-o-meter physician's beam scale,
For any scale you need to have a known weight to calibrate the scale. Try using something like a 5lb bag of flour or 10lb bag of potatoes.
On the top of the scale set the scale to whatever known weight you have on the platform and see if it agrees, if it is just slightly off, then use the adjustment screw to fine tune the scale, it will be at the end of the left side of the arm.
1/4/2011 9:27:46 PM • Health-O-Meter... • Answered on Jan 04, 2011
Unable to change from kg to lbs on my healthometer BFM883DQ-01 scale.
Health o Meter Professional Scale model 822KL won't convert from stones to pounds even after I flip the switch to lbs. It never changes
1/12/2023 9:22:01 PM • Health-O-Meter... • Answered on Jan 12, 2023
How to rest history of health-o-meter scales model numberBFM145-63
turn it off if you wish to REST it
9/14/2021 8:10:34 PM • Health-O-Meter... • Answered on Sep 14, 2021
Instructions manual for Health O Meter BFM081DQ-63 Body Fat Monitoring Scale
To reset a profile hold down the number of the profile you want to reset (1-4) then hold down the select button at the same time. The scale will ask you if you want to erase. Then you can recreate your profile.
9/18/2019 2:03:23 AM • Health-O-Meter... • Answered on Sep 18, 2019
How do i replace the battery on my health-o-meter digital scale, model #613
  1. Place the Health-O-Meter scale on a flat surface. Make sure the scale is indeed level.
  2. Tap the lower left or right corner of the scale three times. After you do this, you'll notice the display shows.
  3. Wait a few seconds for the scale to reset and re calibrate.
7/17/2019 7:47:16 AM • Health-O-Meter... • Answered on Jul 17, 2019
Hi. I have a Healthometer
Try to get a manual at website or a google search.
9/6/2017 10:48:39 AM • Health-O-Meter... • Answered on Sep 06, 2017
2answers
How do replace the battery on a EverWeigh Lithium
The battery is located behind the LCD screen, slightly on the right hand side side if you are facing the LCD screen. You can drill a hole on the platic case from the back of the scale, and you will see the battery house and 3 screws on the battery house lid, unscrew the 3 screws, you can take out and replace the 3V Eveready button type battery easily.
I have tried to open the case by taking out the spring latches located behind the 4 legs of the scale, it was much harder to put every thing back afterward.
Yi from San Jose, CA
8/26/2016 6:50:27 PM • Health-O-Meter... • Answered on Aug 26, 2016
Low blood sodium levels symptoms
sodium is a necessary electrolyte, electrolyte imbalance will cause many uncomfortable symptoms... Pounding heart, fatigue, confusion, and a craving for salty foods (if you didn't have that already.)
4/28/2016 6:59:50 PM • Health-O-Meter... • Answered on Apr 28, 2016
0answers
What does it mean if a have not bled for 2 weeks and am now?
if this is normal menstruation - do not bother, it happen from time to time, if it begin to every two weeks - then start to worry. if you are on tablets - it maybe that you did forget hormone tablets and take dummy one you did not state how old you are, did you have any other related problems, "bre a st" problems, or hormonal problems? do not hesitate to ask for further explanation if needed. fixya find certain parts of women anatomy a profanity in normal spelling...
1/3/2015 1:51:51 PM • Health-O-Meter... • Answered on Jan 03, 2015
Health o meter bfm081dq-63 doesn't turn on after installing new batteries
I found one and it wouldn't come on either after I put new batteries in it, I took it apart and cleaned the battery terminals with some sandpaper. I put batteries in it and it turned right on.
11/11/2014 1:43:44 PM • Health-O-Meter... • Answered on Nov 11, 2014
2answers
I have a Health O
Current Instruction Manual for the HDM560 can be found here:
http://www.healthometer.com/Manuals/MANUALS/HDM560-05_43_41816518.PDF
For resetting it would be similar to the initial setting process. FOLLOW these steps:
Lift display cover. Push "SET" button at bottom of pad. User "1" and "2" will appear.
User "1" will start blinking. Press the "USER" button to choose user "1" or "2". Once selected, press "SET" button to lock in information.
Both "HEIGHT" and "AGE" will appear on the screen. The "HEIGHT" will start blinking. Press the "UP" or "DOWN" arrows to find the correct height.
After entering height, press the "AGE" button. Use the "UP" and "DOWN" arrows to enter correct age and press "SET".
Both "MALE" and "FEMALE" images will be displayed. Press the "GENDER" button until the correct MALE/FEMALE image blinks and then press "SET". This will lock in the information.
Your correct information including User, Height, Age, and Gender will be displayed. Now you are ready to calculate weight.
Tap your person "USER" number (1 or 2) in center of scale with your toe. Your personal profile will appear. Wait until "000" appears. Stand on scale so bare feet are positioned over silver pad surface. "000" will blink your weight for approximately 3 seconds. "BF" will flash and body fat percentage will appear. The scale will turn off automatically in a few seconds.
5/10/2014 5:24:52 PM • Health-O-Meter... • Answered on May 10, 2014
Health-O-Meter Health o meter 402KLWH Physician's Beam Scale With Height Rod  Wheels Logo
6 questions posted
Top Health-O-Meter Health & Beauty Experts
NOEL
NOEL
Paula Hamilton
winchester
winchester
Are you a Health-O-Meter Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Health-O-Meter Health & Beauty
Most Popular Question
health o meter physicians beam scale
  • Health & Beauty
