20 Most Recent Briggs & Stratton Briggs Stratton 7 kW Auto Standby Generator Questions & Answers
The transfer switch is responsible for starting / stopping the generator. Check your auto - start circuit. It is 2 wires that go between the genset and ATS. They are generally normally open. When the genset is to shut down this circuit needs to change state.
Briggs &... | Answered on Jan 08, 2019
sounds like problem with c board still a problem
Briggs &... | Answered on Sep 18, 2017
You have a fuel delivery issue that can be dealt with by cleaning carb or replacing it. If you do replace carb has to be adjusted to the motor.(idle, mixture)
Briggs &... | Answered on Sep 03, 2017
It shuts down because it's not making power. You are probably getting a failure to start error code. If it doesn't make power it doesn
t know its running. Rotor has lost residual magnetism to start the voltage regulator. Replace the voltage regulator. The new one is designed to overcome this.
Briggs &... | Answered on Dec 14, 2014
Hi and welcome to FixYa, I am Kelly.
Spend some time reading this manual after you download it:
http://www.guardiangenerators.com/PublicPDFs/0F7698.pdf
This is how the manual page 99 says you should set the weekly exersise cycle:
(this should be the same for your generator)
SETTING WEEKLY EXERCISE CYCLE
The generator will start and exercise once every
seven (7) days, on a day and at a time of day selected
by the installer or operator. The unit will run for
approximately 13-15 minutes during this "exercise"
cycle, and will then shut down. Transfer of electrical
loads to the "standby" power source will not occur
during the exercise.
A switch located on the generator control console permits
the day and time of exercise to be selected. To
select the day and time of day for the system to exercise,
proceed as follows:
• Place the AUTO-OFF-MANUAL switch to its OFF
position.
• Hold the set exercise time switch at its ON position
for about five (5) seconds.
• After five seconds, release the set exercise time
switch to its OFF position. Wait 30 seconds, then
place the AUTO-OFF-MANUAL switch at AUTO.
The generator will exercise every seven (7) days at
the selected time.
NOTE: Failure to wait 30 seconds before placing
the AUTO-OFF-MANUAL switch to AUTO may
result in engine cranking and startup. If the
engine does crank and start, it will shut-down
automatically within about two (2) minutes
If it still does not work... Check the Utility Power line transformer resistances in the transfer switch. Also check the terminal board in the transfer switch for any corrosion or signs of heat.
All Terminals connections N1, N2, T1, T2, E1, & E2 should be tight and clean.
If you need more assistance just respond here and I will help you.
Kelly
Briggs &... | Answered on Jul 01, 2013
rectifier bad.
Briggs &... | Answered on Feb 10, 2013
Can you manually adjust the voltage on the generator without load?? If you have 120/240 60hz output on it and you are not overloading the unit (amperage), then it may be as simple as adjusting whats called your gain setting for your voltage regulator. Obviously you are seeing what happens when it is set too low. Trying raising that setting until it becomes unstable then back it off. Unstable meaning voltage starts jumping all over.
Briggs &... | Answered on Jul 15, 2011
There are Three things a Motor needs to work, Fuel, Spark, Air. So you simply check each step, If you have Fuel, and you are sure it's getting to carburettor, then, First check, spark plug, (Replace is best), spark plug leads, and Ends. See if there is a "Spark" when the Motor is turned over. IF there is a good spark, OK, if NOT find out why, check, coil, check, points/Electronic ignition. Alternator. IF all good there,then Check, carburettor, Needle valve, Jet, float bowl, float and valve, check mixture. www.repairfaq.org/samnew/lmfaq.htm www.briggsandstratton.com/maint_repair/ www4.briggsandstratton.com/display/router.asp?DocID.
www4.briggsandstratton.com/.../Carburetion_Troubleshooting_Detail_Reference_Guide.pdf - http://www.smallengineadvisor.com/memberdetails.htm
Those links above should help you find and fix.
Briggs &... | Answered on Jul 11, 2011
Electric clocks use synchronized motors that run on 60 Hz AC. The power company provides AC power with a precisely regulated frequency of 60 Hz. That means that the voltage jumps back and forth (positive to negative) 60 times per second. Your generator would do the same thing if it could run at precisely 3600 rpm (that's rev's per minute) - but it can't, because the engine is not that precisely controlled. In your case it tends to run (on average) a little fast. I hope you found this helpful. By the way, in Europe 50 Hz is the norm. If you run a clock designed for 50 Hz on 60 Hz power, it will run 20% too fast! Al K
Briggs & Stratton Briggs  Stratton 7 kW Auto Standby Generator Logo
Popular Tags
29 questions posted
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Sheldon Dedek
Mike
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Briggs & Stratton Electrical Supplies
Most Popular Question
bought new no problems until two weeks
  • Electrical Supplies
