20 Most Recent
Generac Power Systems Generac 5793 Ix 2000 Watt Portable Inverter Generator Questions & Answers
I have a generac ix
You engine has a low oil level sensor. If the oil level is low or..... the sensor is bad it will ground the ignition from the coil with the engine switch on. For troubleshooing only disconnect ONE wire from the sensor AFTER you make sure the engine oil level is properly serviced. Then check for spark.
If this does not correct the problem just respond and I will help you.
Thanks for choosing FixYa,
Kelly
Why isn't it producing rated output?
Rated output is at full load. Units will produce power up to that limit and use gas accordingly. Very lite load = less output and less gas consumption, etc.
Generac 5793 Ix 2000 surging
It sounds as though there is an issue with the carburetor. If the unit is "surging" with no load I would recommend thoroughly cleaning the carb. It would also be a good idea to test the fuel pump. Per Generac you need to disconnect the fuel line leading to the carb and pull the starter rope over to see if adequate fuel is flowing. If none of this is the issue try testing the stepper motor on top of the carb. If you unclip the wire and use an OHM meter all wires should test at 150 ohms. to test place on test lead on the blue wire and move the other lead to the remaining four wires. The should all ohm out to roughly 150ohms. if this is not the case you need to replace the stepper motor.... Before you do any of this you should check for fresh fuel, a good spark plug, and proper compression.
