20 Most Recent Honda Black Max 2600 PSI Pressure Washer Questions & Answers
WHAT OIL SHOULD I USE
If you are asking about the oil for the gasoline engine then you can use a 30 weight engine oil like you would use in a car engine. Pressure washer pumps use a special non-detergent oil which is not the same as the engine uses.
5/20/2021 10:42:22 PM • Honda Black Max... • Answered on May 20, 2021
2answers
Why is there no pressure on the Honda 2600 pressure washer?
SEALS CHECK PUMP ASWELL
4/20/2019 2:01:52 PM • Honda Black Max... • Answered on Apr 20, 2019
Honda GC190 pressure washer has no compression
take the plug out and put a screwdriver in the hole turn the engine over by hand if it does not move the piston up the connecting rod has broken.
6/3/2017 11:10:38 PM • Honda Black Max... • Answered on Jun 03, 2017
How do you drainoil so
lornaa, you can get a copy of the user manual from this link. It has come directly from the manufacturer.
thanks and good luck
iain
1/16/2017 3:07:49 PM • Honda Black Max... • Answered on Jan 16, 2017
2answers
Engine stalls when not using wand
Frank, either the unloader valve is out of adjustment(try loosening it off) or it is faulty and needs rebuilt or replaced as most people do. Check the attached vids,instruction and guides, Good luck "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
8/10/2016 6:21:47 PM • Honda Black Max... • Answered on Aug 10, 2016
I start using it and after 5 to 10 minutes it stops and it does not want to start.
try to replace the spark plug. after time they tend to break down at high temperatures. if that isn't it it may possibly be the coil
5/22/2016 9:53:26 PM • Honda Black Max... • Answered on May 22, 2016
Honda gcv160 pressure washer washer has no
I would be happy to advise you further and give you more detailed answers then the others have. Guessing at an engine or unloader problem will not actually assist you in getting your pressure washer up and running again. The most important question is, what is your pressure washer model number? That is the first part of this process. Honda is just the manufacturer of the engine that you have. They don't build pressure washers. If you can provide the model number, you should be able to find this on the cart or frame of the unit, then I can determine what pump you actually have and assist you in determining the actual problem to get your pressure washer up and running again. There are a few issues that can cause this problem, all of which can probably be repaired with minimal cost. If you can provide me with more information I would happy to assist.
11/4/2015 5:09:12 AM • Honda Black Max... • Answered on Nov 04, 2015
Broken plastic water inlet connection.
I have the same problem. The design is bad with the weight of the hose and the lelength of the plastic inlet tube from the body creates a sheer force that causes it to break. I cannot find anything but a plastic inlet part. If someone would create a metal inlet connector they could make a lot of money. You need a lot of hose slack when moving your power washer or it will break off the inlet and the parts are abotu $20. Very poor design!!
10/21/2015 10:21:24 AM • Honda Black Max... • Answered on Oct 21, 2015
Where can I get a rebuild kit for pump?model XR-2600.
remove the pump and throw it away. Buy a better designed pump on eBay. just search your pressure washer model number or the obsolete rebuild kit part number a14292 you'll find the better pump.
1/30/2015 9:05:16 PM • Honda Black Max... • Answered on Jan 30, 2015
Rope pull start is stuck, won't pull out
Check the oil level, if it's very low or burnt then it may have siezed up internally. It could also be that be that the cylinder is filled with oil or fuel. if the washer was tipped over the fuel or oil may have migrated in to the piston combustion area.
11/2/2014 3:18:45 PM • Honda Black Max... • Answered on Nov 02, 2014
Suds won't draw from tank
make sure the hose from the tank is not split or cracked where it draws from the tank
9/1/2014 5:18:13 AM • Honda Black Max... • Answered on Sep 01, 2014
Honda blackmax 2600pressure washer will not start
Is the gas tank topped off? Is the water hose plugged into it and turned on? Is the gas valve open instead of closed? is the throttle turned on fully? Is the spark plug wire attached all the way? Should work after all of this.
7/23/2014 6:11:33 PM • Honda Black Max... • Answered on Jul 23, 2014
Manage my life com sears
the pump is direct drive from the motor it is not designed to be disengaged by lowering the rpm, it will decrease the pressure a little bit .
7/21/2014 11:48:21 PM • Honda Black Max... • Answered on Jul 21, 2014
Why does my karcher 1750G have no pressure
can't solve this but can you solve why mine leaks oil all the time?
6/6/2014 12:52:48 PM • Honda Black Max... • Answered on Jun 06, 2014
Honda Black Max 2600 PSI Pressure Washer Logo
162 questions posted
Top Honda Garden Experts
Sean Wright
Sean Wright
john h
Jesse Walters
Jesse Walters
Are you a Honda Garden Expert? Answer questions, earn points and help others
View Most Popular
Honda Garden
  • Honda Garden
Most Popular Question
oil use
  • Garden
