20 Most Recent Comet Bwdk3027g Triplex Pressure Washer Pump 2700 Psi Questions & Answers
I have COMET CAWD1069 front loading washing machine with EC6 error code?
The washing machine doesn't exist https://www.google.com/search?q=COMET+CAWD1069 And the EC6 Error is only mentioned here for Frigidaire. https://www.appliancevideo.com/repair-help/question/ec6-error E6 is the common error in washing machines in Whirlpool, LG and Defy. https://www.google.com/search?q=washing+machine+E6+Error ...
9/29/2023 7:30:37 PM • Comet Garden • Answered on Sep 29, 2023
Can I clean my bath tub with muriatic acid
You can utilize the grating idea of muriatic Acid - a typical mineral acid - to free your bath of rust stains. Muriatic acid is accessible from your nearby home improvement shop and should be dealt with cautiously as it is quite caustic.
2/20/2020 3:48:36 PM • Comet Garden • Answered on Feb 20, 2020
What is the nominal consumption in amps of the comet ka 2500's motor
2.9 kw/h up to 4.5 kw/h depending on the model.
8/3/2015 1:23:23 AM • Comet Garden • Answered on Aug 03, 2015
Little plastic parts behind the six big nuts on brass end of the pump have melted.
Hi These are the valves If they are melted this is because the washer is being left running without being triggered. I also suspect yoru unloader may be failing...your will want your unloader tested. The only way to test anything is to replace these valves first. unfortunately I would also inspect your packings as well as the pistons. when water builds up for a length of time without triggering the washer it recycles and builds up heat....this heat starts to melt your valves....this can also happen by starving your pump for water....running it without water....or by a failed unloader where it doesnt allow water to bypass...do you have to pull the trigger of your wand to start it? If so then your unloader needs work. If it has been starved for water..then your packings will show that damage as well...Usually the farthest set from the inlet having the most damage. Also, when that all get hot as soon as you trigger it and cold water is introduced into the pump, this "shocks" the pump packings and pistons. You want to check the pistons to see if they have cracked..So inspect your pump oil for water...look to see if its white-ish looking... Check your pistons for cracks...check your packings for wear. If you see wear that increasingly gets worse the farther away from your pump inlet then thats a tell tale sign of starvation. ..if your pistons are cracked you will need to replace packings as well anyway. Then replace your valves...reassemble and test your unloader. Good luck to you man. You can get all parts here Pressure washer parts catalog quick links Pressure Washers High Pressure... or FIND PARTS FAST
2/26/2015 9:46:28 PM • Comet Garden • Answered on Feb 26, 2015
What is a comet
Comet is a company that makes high pressure washer pumps. Usually sold by northern tool
2/23/2015 12:02:35 AM • Comet Garden • Answered on Feb 23, 2015
ZWD 4030 manual needed
service manual https://www.pwmall.com/PDF/CometServiceManual.pdf
12/16/2014 3:08:45 AM • Comet Garden • Answered on Dec 16, 2014
Comet axd 3020 will not build pressure
junk axial wobble plate pump. Usually axial pumps are not worth the time to try to fix them. This one has a 5 year warranty , so they think they have a pretty good one. ( I would never buy one) If you want to try to fix it, I would check the check valves first. Take them out and see if some are broken or not sealing properly. There is a valve kit available. The other likely problem is your unloader valve. If the seal is shot or the valve stuck open the pump will not build pressure. parts diagram http://www.ppe-pressure-washer-parts.com/files/1961581/uploaded/axd-PUMP%20BREAKDOWN.pdf
12/16/2014 2:59:12 AM • Comet Garden • Answered on Dec 16, 2014
0answers
0answers
0answers
Where does the detergent siphon hose connect on
From the hydraulic pump. there should be a little nub to place the hose on
8/9/2013 7:54:28 AM • Comet Garden • Answered on Aug 09, 2013
Looks like fuel isn't getting to the carburator
If you are using gasoline that has alcohol in it for air pollution control, it may have ruined the seals in the carb.
5/20/2013 4:17:47 PM • Comet Garden • Answered on May 20, 2013
Comet Bwdk3027g Triplex Pressure Washer Pump 2700 Psi Logo
Popular Tags
1 questions posted
Top Comet Garden Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Comet Garden Expert? Answer questions, earn points and help others
View Most Popular
Comet Garden
  • Comet Garden
Most Popular Question
nominal consumption in amps comet ka
  • Garden
