20 Most Recent FAIP 2100psi 2gpm Faip Power Pressure Washer Pump Only Questions & Answers
What type of oil is used to fill the a FAIP
I don't know about that brand of power washer.
We used several types of power washers over the years, and they each called for 20 or 30 weight non-detergent oil in the pump. SAE 20 or SAE 30
The pump oil comes about half way up inside the pump.
The engine oil is 10W30
Do not turn a power washer on its side or upside down or oil will run into carburetor.
10/15/2010 6:25:08 AM • FAIP 2100psi... • Answered on Oct 15, 2010
Replacement parts for model 1650 power washer
1.Electric Male plug 2.Pressure Hose 3 ON/OFF switch
8/30/2019 2:05:39 PM • FAIP Garden • Answered on Aug 30, 2019
FAIP H120 ELEC. POWER WASHER,COMPRESSOR RUNS,NO SPRAY
The water supply may be blocked. Check filters, screens, or it may be air-locked.
6/18/2017 9:31:53 PM • FAIP Garden • Answered on Jun 18, 2017
0answers
Model H120
Be the first to answer 6/24/2014 1:59:38 AM • FAIP Garden • Posted on Jun 24, 2014Be the first to answer
0answers
0answers
1900 manual
Be the first to answer 3/29/2014 5:02:51 PM • FAIP Garden • Posted on Mar 29, 2014Be the first to answer
0answers
2answers
Where can I get seal rings and o rings for my
Alot of people have tried doing this as the genuine o-ring and seal kits are so expensive and sometimes hard to source, but many companies make orings and seals that are unique and cannot be found aftermarket,
If you are lucky you may find some but the only way of doing so would be to take the actual seal and orings down to your local bearing and seal supplier and they will measure it up and do their best to find some for you...
Regards
Brad
10/12/2013 8:19:55 PM • FAIP Garden • Answered on Oct 12, 2013
Faip model H120 doesn't shut off
The contacts on the microswitch have probably eroded a bit with age. The simple fix is to remove the red cover and adjust the setscrew that hits the microswitch plunger. Loosen the locknut and use an allen wrench to adjust the set screw. If you aren't sure which to adjust, power up the washer and pull the trigger while watching the motor assy. You'll see an arm moving outward when the trigger is released and in when you pull it. Follow this arm to the adjusting screw. Had the same problem with mine and had to move the screw OUT a half turn.Hope this helps.
10/12/2013 8:12:48 PM • FAIP Garden • Answered on Oct 12, 2013
0answers
1650 power
Be the first to answer 9/9/2013 4:32:57 AM • FAIP Garden • Posted on Sep 09, 2013Be the first to answer
0answers
FAIP 2100psi 2gpm Faip Power Pressure Washer Pump Only Logo
2 questions posted
Top FAIP Garden Experts
Jay Finke
Jay Finke
john h
Are you a FAIP Garden Expert? Answer questions, earn points and help others
View Most Popular
FAIP Garden
  • FAIP Garden
Most Popular Question
type oil used fill faip
  • Garden
