20 Most Recent Honda Landa PG 3500 PSI Pressure Washer Questions & Answers
Check out the trigger mechanism. Water should come out at any time, even when you do not have the unit started.
Honda Landa PG ... | Answered on Aug 22, 2016
The issue with the black smoke could be a number of different things, the fuel filter could be bad, the air to fuel ratio on the burner system could be off and needs to be adjusting, this is difficult to do if you have never worked on a system like this before.
The issue with the burner not turning off would have to do with the pressure switch, flow switch or the thermostat. With a pressure washer like this the power in the electrical system will run through these different items and either say light or don't light. More than likely if your burner is staying on though it is going to be the flow switch that is sticking, I am not the most formular with the system that they have on this machine but that is the first thing I would check.
Honda Landa PG ... | Answered on Jan 30, 2015
Landa does not have a model HMP so I am not sure which machine you have. If you can provide a full model and serial off of the model tag on the machine I can provide you with a digital copy of the manual you are looking for.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
800.247.8103
503.255.6508
Honda Landa PG ... | Answered on Mar 02, 2012
Assuming that the engine has not been taken apart and timing is set correctly. Have seen this often. Usually valve adjustment. Adjust valves as per manual so that compression release is working. If compression release is not working after adjustment check for faulty cam.
Honda Landa PG ... | Answered on Oct 23, 2011
It will depend on the pump that you have but the most common versions will be the 13HP PC4-35324 which is a direct drive unit or a PG4-35324 which is a belt drive unit. In both cases the machine would be 4GPM at 3500PSI.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
800.247.8103
503.255.6508
Honda Landa PG ... | Answered on Feb 14, 2011
The problem you are describing lies in the engine. In most cases this can be cleared up by doing a tune up. In the meantime you can try choking the engine slightly and see if that keeps it running under pressure. This will usually solve the problem with the smaller GC and GX series Honda engines until you can do the general maintenance.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Honda Landa PG ... | Answered on Feb 13, 2011
The pressure adjuster you are talking about is actually your unloader which is a pressure relief valve. It is normal for this to pop up and down as it moves in and out of bypass mode. Your pressure issue could be a failed unloader, valves or packings in the pump. You will need to bypass your unloader valve to find if the issue lies in the pump or if it is simply a failed unloader. If you have any questions, need parts or service, please feel free to contact me using the information below.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Honda Landa PG  3500 PSI Pressure Washer Logo
Popular Tags
41 questions posted
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
View Most Popular
Honda Garden
  • Honda Garden
Most Popular Question
honda 13 hp start back fires
  • Garden
