20 Most Recent
Faip Powerwasher 1800 Psi 16 Gpm Pressure Washer Questions & Answers
Where can I get seal rings and o rings for my
Alot of people have tried doing this as the genuine o-ring and seal kits are so expensive and sometimes hard to source, but many companies make orings and seals that are unique and cannot be found aftermarket,
If you are lucky you may find some but the only way of doing so would be to take the actual seal and orings down to your local bearing and seal supplier and they will measure it up and do their best to find some for you...
Regards
Brad
10/12/2013 8:19:55 PM •
FAIP Garden
Answered
on Oct 12, 2013
Faip model H120 doesn't shut off
The contacts on the microswitch have probably eroded a bit with age. The simple fix is to remove the red cover and adjust the setscrew that hits the microswitch plunger. Loosen the locknut and use an allen wrench to adjust the set screw. If you aren't sure which to adjust, power up the washer and pull the trigger while watching the motor assy. You'll see an arm moving outward when the trigger is released and in when you pull it. Follow this arm to the adjusting screw. Had the same problem with mine and had to move the screw OUT a half turn.Hope this helps.
10/12/2013 8:12:48 PM •
FAIP Garden
Answered
on Oct 12, 2013
020209 pressure washer has no pressure
Your water inlet may be stopped up. Whether this model only has a screened hose washer or a better filter, pay special attention to that. Be sure the pathway is free and clear.Take each of poppet valves and while pushing (with a pencil or something) on the part that moves up and the spring pushes it back down - with magnification and lots of light, be sure there isn't a small piece of debris affecting one of those valves. Its easy to miss, so look very closely. Next, remove the hose from the pump. We are by-passing the entire unit that includes pressure hose, trigger gun, lance, spray nozzle. If it seems to pump a lot of water out of the pump--then the problem is most likely the trigger gun is clogged or the pressure nozzle is clogged. Some trigger guns can be taken apart -- some, not so much. Same with nozzles. I hope this helps you, Randell. If yes, please take a sec to rate me. Thanks!Don
3/25/2012 4:35:01 AM •
FAIP Garden
Answered
on Mar 25, 2012
