20 Most Recent
Dewalt DPD3300 Commercial Pressure Washer Questions & Answers
My dewalt dpd3300 ,why is it getting gas in the oil
This happens when the gas needle valve in the carburator sticks open. With it open, gas continues to flow into the carburator then into the cylinder and finally down into the crankcase. It can be caused by dirt in the needle valve's seat, a stuck needle or float. Most of the time you can remove the float bowl and flush out any dirt. If there's a lot you should consider flushing the gas tank and check your gas can for dirt. If the washer has been sitting for a long time the problem could be varnish is gumming up the carb works. Carb cleaner works well to flush that out. If the float, needle or seat is damaged you'll have to rebuild or replace the carb.
I would like to know if this pressure wahser use
If your engine has a place to put oil, then your power washer uses ordinary gasoline.
The only type engine that uses 2-cycle oil and gas mixture is engine that has no place to put oil.
Oil for pump comes half way up >>> pump uses SAE20 or SAE 30 non-detergent motor oil
Oil for engine comes half way up dip stick and uses 10-W30 motor oil
Engine does not start easily after shut off
if there is water pressure still hooked up then pump is primed and a sensor { that kicks the idle down when not pulling the trigger} is restricting the fuel flow. see if problem continues without pressure
