20 Most Recent Tally Line Matrix T6050 Printer Questions & Answers
2answers
How can i able to free download process of tally
Hi you can download all version of Tally i.e. Tally 9, Tally 8.1 and Tally 7.2 from this site http://www.apnitally.com alternatively the latest version of software i.e. Tally 9 can be downloaded from
http://www.tally.co.in
1/1/2019 6:47:00 PM • Tally Line... • Answered on Jan 01, 2019
DISPLAY SETTING T6050 PRINTER
I'm not 100% sure what you are asking here, but on that printer to navigate the menus is a bit odd. Scroll to the option you want and press the key with the '1' on it then scroll to your next option and press the key with the '2'. The next menu option uses the '3' and finally you would use the enter key to display the value for the option that you navigated to using the '1,2,3' keys.
1/6/2016 2:17:19 PM • Tally Line... • Answered on Jan 06, 2016
0answers
T6050 printer i am geting paper jam problem
adjust hammer gap
1/10/2015 7:02:52 AM • Tally Line... • Answered on Jan 10, 2015
Vibration in the paper ,as a result print is coming blurry in the T6050 printer.
release some gap by platen manually pull up. and calibrate hammer. for better printing
1/10/2015 6:53:20 AM • Tally Line... • Answered on Jan 10, 2015
T 6050 trunk faild
clear nvram ram first
1/10/2015 6:50:40 AM • Tally Line... • Answered on Jan 10, 2015
0answers
Self-testing
Logic card Problem. Change Logic card
5/29/2014 8:14:06 AM • Tally Line... • Answered on May 29, 2014
Lipi t 6050 in offline mode
Please Clearly mention your Problem?
5/29/2014 8:12:29 AM • Tally Line... • Answered on May 29, 2014
T6050 Printer not booting
there may be two problems in the logic card of the printer 1 .ONE OR MORE RESISTANCES R165 , R166 , R167 , R170 , R171 MAY BE DEFECTIVE.. 2 . FIRMWARE MAY BE CORRUPTED , RELOAD IT.
4/29/2014 7:04:22 AM • Tally Line... • Answered on Apr 29, 2014
Lipi t6050 printer going to offline mode 1 min after poweron
check wheather printer is restarting , input voltage must be 48v dc for logic card check resistances r 165, r166 , r167 , r170 , r171 on the logic card if input voltage is ok
4/29/2014 6:58:53 AM • Tally Line... • Answered on Apr 29, 2014
T6050 self testing
If u r a repair technician here are some useful steps 1. check rp1 to rp13 resistance pack ( 47 ohm and 33 ohms ) 2. download firmware 3. touchup the flash and font rom (U33 , U34)
4/29/2014 6:49:31 AM • Tally Line... • Answered on Apr 29, 2014
Lipi6306 matrix printer not going to offline mode always in online configure 1
step 1 : change the panel cable step 2 : change the control panel step 3 : download firmware as follows : T6306 FIRMWARE DOWNLOADING PROCEDURE
  1. Connect the printer to pc through parallel port.
  2. Press "FF + ^ + CONFIG" at the control panel and power on the printer .
  3. Panel will show "ready to download".
  4. In dos mode type "vdv3000r -pb" and enter .
  5. After completing the firmware loading printer may show NVRAM fault.
  6. Press "CLEAR"and printer will restart to finish.
4/29/2014 6:43:00 AM • Tally Line... • Answered on Apr 29, 2014
6050 belt slips continously
replace the shuttle belt or fix insulation tape on the pulley of both shuttle motor and shuttle wheel and then refix the belt.
4/29/2014 6:34:23 AM • Tally Line... • Answered on Apr 29, 2014
Power board
the problem is not mentioned exactly . By the way you can check the out put voltage +48 v DC at the output cable which is connected to logic board . If it is not there , check fuse 3.15 AMP , thermistor , IRF 840 , if u r technical and knows how to repair .
4/29/2014 6:31:18 AM • Tally Line... • Answered on Apr 29, 2014
0answers
Tally Line Matrix T6050 Printer Logo
113 questions posted
Top Tally Office Equipment & Supplies Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Tally Office Equipment & Supplies
Most Popular Question
error memory access voilation c0000005
  • Office Equipment & Supplies
