20 Most Recent
Tally LA650 Matrix Printer Questions & Answers
I have a miss my tally activation key & Serial
FixYa and it's experts
do not provide product keys, serial numbers, illegal software,
authorization numbers or codes, warez, hacks or cracks under any
circumstances. Any expert that does so will be barred from answering
questions. Those asking are subject to their membership being deleted
and be barred from the site.
If you
have previously registered the software or have a proof of
purchase for the software, contact the manufacturer and they
will provide you with a new product key.
Thanks
for using fixya
Regards
PCmania
HEN I WAS OPENING TALLY ERP 9 I HAVE BEEN FACING
Step 1
Windows Key+R
in the Run Box
Type your Tally Folder Path as following
Eg. D:\Tally.erp9\tally.exe data 0
when open Tally Getway
use Ctr+Alt+R
Rewrite All Company
Enjoy....
IF Problem is same
then in the data folder company number folder
delete all tsf file and attem step 1 again
Problem is 100% solved.
AYS, Beawar,
Thanks to Mir -- Manish JI Garg..
Printed 12 inches
check the page setup for header and footer margin sizes and top or bottom margin sizes .
How to maintain tds in
Please follow the below link for your problem.
http://www.tallyinfo.com/resources/help_files/index.html?tds_tds_in_tally.htm
thanking you
davevipul197
How to convert tally 4.5 data to tally 7.2
please follow the below link for your problem.
http://www.tally9.info/2008/09/data-migration-converting-tally-45-data-to-tally-9-data/
you can find your answer left side in this website.
thanking you
davevipul197
WHAT IS DEBIT NOTE
It is a sales document used in complaints processing to request a debit memo for a customer. If the prices calculated for the customer were too low, for example, calculated with the wrong scaled prices, you can create a debit memo request. The debit memo request can be blocked so that it can be checked. When it has been approved, you can remove the block. It is like a standard order. The system uses the debit memo request to create a debit memo.
A transaction that reduces Amounts Receivable from a customer is a credit memo. For eg. The customer could return damaged goods. A debit memo is a transaction that reduces Amounts Payable to a vendor because, you send damaged goods back to your vendor.
Have a nice day and do not forget to rate please...!
Unable to create company path c\tally.erp 9\Data\10005
Does your user name and password have administrative rights on the computer? If not then you may need try with a user that does. I have run into some software that will throw a similar error if the folder already exists.
