20 Most Recent Bosch Gsh 16 Demolition Hammer Breaker Questions & Answers
2answers
Need owners manual Bosch 11305 Demolition Hammer
notify bosch or dealer
12/2/2021 6:04:59 PM • Bosch Hammering • Answered on Dec 02, 2021
Bosch Demolition Hammer Drill 11241evs striker c-ring removal picture or video?
https://www.youtube.com/watch?v=JMGwvpDpu9w
5/11/2020 5:50:59 PM • Bosch Hammering • Answered on May 11, 2020
How do i trobule shoot my bosch hammer drill, does not turn on
get a multi-meter and test switch and wiring
10/16/2019 12:55:05 AM • Bosch Hammering • Answered on Oct 16, 2019
Where do i put in oil on bosch 11305 demo hammer
Beware for all not all parts are more available, there is no oil used only Grease Service Pack 1617000036 for Bosch Power Tool eReplacement Parts
8/12/2018 10:31:19 AM • Bosch Hammering • Answered on Aug 12, 2018
Bosch hammer electric Hammer Jack is losing power and shutting off
The efficient design of Ingersoll Rand 114GQC Air Hammer allows the users to quickly change the spindles on the drill. It is able to deliver 2-5/8 inches of strokes with a BPM speed of 3500 so it ensures total efficiency.
6/7/2018 6:00:30 AM • Bosch Hammering • Answered on Jun 07, 2018
Was using my Bosch brute 70lbs jackhammer and it quit working. It only makes a humming sound when I press trigger.
Beware Time for service something does blocking the armature if that happens a bearing or other broken part.
5/6/2017 7:02:10 PM • Bosch Hammering • Answered on May 06, 2017
Can a bad trigger cause my Bosch brute jackhammer not to run correctly
First to look for faultering contacts on electric field and carbon brushes sometimes a suppression capacitor can give some problems a worn commutator on the armature a switch can be overhauled with a direct cable contact to test to know if it is the switch test it out only with 2 persons for safety in that case.
5/6/2017 7:00:00 PM • Bosch Hammering • Answered on May 06, 2017
Because my Bosch 11316EVS does not turn on
Bosch Parts Service Online Illustrated Part List Control the power cable for wire breakage second remove the carbon brushes and control them on the collector surface for if there is a little black pin was coming out of it thats an auto protection build in then replace the brushes , but there are more things because there can be a problem with the electric field on a contact measure both coils and all the collectors (commutator around) on the armature that there is no-one lost the last option is the electronics
5/6/2017 6:35:31 PM • Bosch Hammering • Answered on May 06, 2017
My bosch jackhammer suddenly stopped working. What the most likely cause? stop
It probably went on strike to demand more money and/or more benefits.
4/25/2017 9:00:54 PM • Bosch Hammering • Answered on Apr 25, 2017
Why my Bosch brute jackhammer only hums when I press trigger? Can someone help me please?
seems as if the jackhammer motor is locked up and frozen might wanna be careful opening it up and freeing that motor up while its unplugged
4/17/2017 3:27:47 PM • Bosch Hammering • Answered on Apr 17, 2017
I have a bosch jackhammer 11388, motor runs fine but the bit not cutting
Position 856 1617000836 a broken hammer piston in the worst case but you have to order 1 617 000 A15 a maintence kit and special lubrication used 50 ml 1 615 437 512 INSPECT CAREFULLY THE 1 617 000 838 Hammer Pipe for rips if all parts are unmounted of the hammer pipe tap it with a metal object then it should not have any dull sound treat like a tuning fork for control for rips. thats important before repair consideration before. The lubricant will be quite thick and that can also be the case only , (only have had its working hours on it) the revision of this hammers are easy to do it yourself clean solvent all metal parts that you re-use again to do the job you have a bench-vise and tools , for the striker pin in case there are no special tools neccesary like other hammers like a suggestion the Milwaukee 500S or other proffesional hammer because of the need of special seals and tools are neccesary , in between 1 and 2 hours are taken to service this Bosch hammers sometimes its neccesary to be aware of 1 ring to replace first of all because its easy to forget this ring on position 104 1610210095 o-ring that will very easy forgotten in practise with some grease replace it first of all spare parts. Bosch Parts Service Online Illustrated Part List
4/9/2017 9:32:51 AM • Bosch Hammering • Answered on Apr 09, 2017
What are the measurements of the connecting rod?
between all the collectors measure from the 2 the brusholders by slow turning around step by step the commutator and read at every step the resistance value, that should be on every step (almost) the same value if there is a gap on one step then replace the armature and in most case the associated drive sprocket because of in some cases a bad noise comming fromout the tool if the tool is much used. Always measure the electric field that its also in balance. the values are depend on model (the wattage)
10/19/2016 1:58:42 PM • Bosch Hammering • Answered on Oct 19, 2016
My bosch 11316evs pause during hammering
COld be the powercable (think on the electric field by the sliding contacts) or a to short carbon brush or a broken ring on the impact bold in front inside , pauze can be mechanical or electric.
6/24/2016 5:22:42 PM • Bosch Hammering • Answered on Jun 24, 2016
Bosch Gsh 16 Demolition Hammer Breaker Logo
3 questions posted
Top Bosch Hammering Experts
john h
ADMIN Andrew
ADMIN Andrew
jabbar huusain
jabbar huusain
Level 1 Expert
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
View Most Popular
Bosch Hammering
  • Bosch Hammering
Most Popular Question
bosch gsh 16 pro jackhammer motor runs
  • Hammering
