20 Most Recent
Toro 42'' Zero Turn Lawn Mower 22hp Kawa Consumer Questions & Answers
Engine runs, blades turn but mower will not move
Look in front of back tired on frame, not deck, there are. 2 rods, 1 on each side, rods look like a L, it's going through a little eye opening, push it backards, mower should move. If rod is pulled through opening and locked in, mower will not move..its a safety. Feather on mower
Why does it keep blowing the 30 amp fuse as soon as I turn the switch?
You have what is commonly called an "Dead Short". Meaning that one or more wires that carry positive flow from the battery is grounded against the frame (In most cases that I have seen) Tracing a short can be a hair raising experience if it is intermittent. The first thing to check is the negative battery cable to make sure it is clean and tight. Then follow the negative cable down to the the frame or under the frame and make sure the bolt is tight. Also, if your engine bolts are loose, this also will cause the fuse to blow.
George
Toro Zero Turn adjustment
i have the same problem I wish I knew what was doing it I also changed the shaft and still. Could the blade be upside down?
Beilt
What is the belt for???
