20 Most Recent
Toro TimeCutter Zero Turn Lawn Mower Hourmeter Kit 1129763 Questions & Answers
My FR691v-as07-R toro timecutter's battery discharges while running. Replaced the Battery, voltage Reg and Diode, still discharges.
It sounds like a job for a volt/ohm meter.
I am not familiar with the model but the basic principles are fairly consistent.
Either there is something causing the battery to discharge at a greater rate than the generator can recharge it or more likely the generator simply isn't working or isn't working efficiently.
In order to charge a battery the generator must provide a higher voltage than the battery or current will not flow. Assuming a 12 volt system the voltage of a fully charged and healthy battery is 13.2 volts. The generator must provide a higher voltage and typically would be around 14.5 volts for solid-state or electronic systems and 15.5 volts for electro-mechanical systems.
Scale the voltages up or down for 6 volt or 18 volt or 24 volt systems...
Isolate the battery from any battery-supplied accessories and then with the engine running fairly fast check the voltage across the battery. If only the battery voltage is present it indicates a generator problem.
As well as providing a higher-than-battery voltage the generator and all the associated wiring and connectors must be able to provide the current flow. In the case of problems it is best to go back to basics and carry out a visual check of all the wiring and connections and check the continuity and insulation of the generator windings and wiring, rectifier diodes, brush gear if there is any fitted and earth connections if it is an earth return type system. It is a good idea to use a wiring diagram for reference.
If the generator is a permanent magnet type there have been rare occurrences where a generator has become inefficient due to a loss of magnetism. I repeat this is a rare occurrence and the fault probably lies elsewhere and a systematic approach and reference to a wiring diagram will usually isolate the fault.
Toro z420
you have to adjust your tracking. Your manual tells you how to do this
Toro cutting off
Maybe low oil level, all mowers have a low oil cutoff. 30w oil.
TORO TIME CUTTER SS4235,NOT STARTING,NO ELECTRCAL POWER TO SWITCH
Check wiring for ground. Ensure battery is fully charged or replace. Replace spark plug. Clean or replace air filter. check oil level, all mowers have a low oil start cutoff. Bad gas? Flush out fuel tank by removing gas line, flush fresh gas thru. Reattach gas line, fill with fresh gas, always use Stabile in gas! Check fuel line for cracks and secure connection to carb. Battery should read 12.8 volts or higher. .
Toro str will not start, motor spins but will not fire
Ensure clean fuel. Always use Stabile in fuel. Follow fuel line from fuel tan to carb, ensure no leaks. Remove carb fuel bowl to check float operation. Have pliers to crimp line or use fuel shut off valve. Remove carb float bowl and clean. Float should hang down freely gas should flow. Push float up gas should cut off. Replace spark plug, ensure plug wire snaps on tight. Clean or replace air filter. Ensure oil is full, 30w oil. All mowers have low oil shutoff.
