20 Most Recent Poulan Pro PR550N22SH 22Inch Briggs Stratton 550 Series Gas Powered Side DischargeMulch Lawn Mower With High Rear Wheels (NonCARB Compliant) () Questions & Answers
NGK BM7A/130-799 gapped at .025"
Poulan Pro... | Answered on Dec 12, 2017
The carburetor may need cleaning. If you are getting a "surging"
Briggs and Stratton call for 20 oz but warn to confirm the level with the dipstick reading.
Poulan Pro... | Answered on Dec 07, 2017
On the Briggs and Stratton site they call for 20 oz but tell the owner to confirm the capacity with the dip stick reading.
You can measure the length of the blade or take it off and go to a store and get a mulching blade it doesn't have to be a Poulan Pro
blade a generic mulching blade of the same size will work and be cheaper. Tractor supply handles a lot of different types of blades.
Poulan Pro... | Answered on Dec 17, 2015
I have provided a link on how to change the discharge chute on a walk behind lawn mower. It is usually pretty straightforward across manufacturers so it should be of help to you.
But in quick terms, you lift the chute cover that holds it in place, remove your current deflector, and insert a new one! It's easy!
Best of luck!
How to Replace the Discharge Chute on Toro Walk Behind Lawn Mower
Poulan Pro... | Answered on Oct 12, 2015
Make sure the fuel filler cap breather hole is clear if its blocked it will create a vacuum in the tank which prevents the fuel flowing forward.
Poulan Pro... | Answered on May 29, 2015
Oh really? That's too bad. Do you have a question to ask about lawn mowers though?
Poulan Pro... | Answered on Jan 02, 2015
You can register it online by going to the Sears website.
Poulan Pro... | Answered on Sep 08, 2014
Go by the numbers on the original plug. The gap should always be set at 0.30.
Poulan Pro... | Answered on Sep 04, 2014
30w or 10w30 will work
Poulan Pro... | Answered on Aug 19, 2014
Gap at 0.030
Poulan Pro... | Answered on Aug 08, 2014
Here is b&s 800number have make ,model,serial number handy 800 444 7774
Poulan Pro... | Answered on Jul 10, 2014
No adjustment, automatic governor.
Poulan Pro... | Answered on May 28, 2014
Probably bent the shaft. Disconnect the spark plug to prevent accidental starting and lay the lawn mower on its side. Slowly turn the blade with your hand and watch the center of the shaft. If it wobbles at all it is bent. $150 to $200 job. Probably time for a new mower.
Poulan Pro... | Answered on Mar 10, 2014
you mean it hasnt blown up yet... then your not trying hard enough or your two cycle oil is too good... take it out and put some straight 30w in it... that should help... some people need to stay away from dangerous stuff
Poulan Pro... | Answered on Dec 28, 2013
Poulan Pro PR550N22SH 22Inch Briggs  Stratton 550 Series Gas Powered Side DischargeMulch Lawn Mower With High Rear Wheels (NonCARB Compliant) () Logo
87 questions posted
Top Poulan Garden Experts
roeb
dannydoesita
Marvin
Marvin
Are you a Poulan Garden Expert? Answer questions, earn points and help others
View Most Popular
Poulan Garden
  • Poulan Garden
Most Popular Question
much slack in pull cord poulan pro push
  • Garden
